Connect a DisplayPort-equipped PC to a VGA monitor/projector, with a 6ft cable. The DP2VGAMM6B 6ft active DisplayPort to VGA converter cable lets you connect your DisplayPort-equipped desktop or laptop directly to a VGA monitor or projector with no additional adapters or cables required - a cost-effective solution for enabling your new Mini DisplayPort computer to work with an older VGA monitor or projector.
Plus, because the converter cable supports video resolutions up to 1920x1200 you can convert a DisplayPort video source to VGA without sacrificing video quality.
- StarTech.com 6ft DisplayPort to VGA Cable - 1920 x 1200 - Active DP to VGA Adapter - DP to VGA Monitor Cable (DP2VGAMM6B) - DisplayPort cable - 1.83 m
- DisplayPort cable
- Latched
- Length
- 1.83 m
- Connector
- DisplayPort - male
- Connector (Second End)
- HD-15 (VGA) - male
- FCC, RoHS
- Black
- 3-year warranty
- DisplayPort cable
- Latched
- Length
- 1.83 m
- Black
- Connector
- 20 pin DisplayPort - male
- 15 pin HD D-Sub (HD-15) - male
- FCC, RoHS
- 3-year warranty
StarTech.com Slimline Adapter HDDB15 F/F | In Stock | £5.05 |
StarTech.com DisplayPort to VGA Video Adapter Converter | In Stock | £24.00 |
StarTech.com Right Angle VGA to VGA Cable Adapter Type 2 - M/F | In Stock | £7.03 |
StarTech.com DisplayPort to VGA Video Adapter Converter | In Stock | £15.81 |
StarTech.com 1 ft VGA to 2x VGA Video Splitter Cable – M/F | In Stock | £13.02 |
StarTech.com 3 ft Mini DisplayPort to VGA Adapter Converter Cable – mDP to VGA 1920x1200 - Black | In Stock | £8.14 |
StarTech.com 3 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black | In Stock | £20.09 |
StarTech.com 6 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black | In Stock | £22.31 |
StarTech.com 10 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black | In Stock | £23.78 |
StarTech.com 15 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black | In Stock | £25.49 |
StarTech.com DisplayPort 1.2 to VGA Adapter Converter – DP to VGA – 1920x1200 | In Stock | £16.47 |
StarTech.com DP to VGA Adapter with Audio | In Stock | £23.69 |
StarTech.com DisplayPort to VGA Adapter - 1920x1200 | In Stock | £70.85 |
