StarTech.com 15 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black
Quicklinx: 92P9WS00 Mfr#: DP2VGAMM15B
Length: 4.57m
£6.99 ex VAT
£8.38 inc VAT
Connect a DisplayPort-equipped PC to a VGA monitor/projector, with a 15ft long cable. The DP2VGAMM15B 15ft active DisplayPort to VGA converter cable lets you connect your DisplayPort-equipped desktop or laptop directly to a VGA monitor or projector at a longer distance than a standard-length cable would support, while saving the expense of additional adapters.
Plus, because the converter cable supports video resolutions up to 1920x1200 you can convert a DisplayPort video source to VGA without sacrificing video quality.
StarTech.com 15 ft DisplayPort to VGA Adapter Cable - DP to VGA Video Converter - Active DisplayPort to VGA Cable for PC 1920x1200 - Black (DP2VGAMM15B) - DisplayPort cable - 4.57 m
DisplayPort cable
Latched
Length
4.57 m
Connector
DisplayPort - male
Connector (Second End)
HD-15 (VGA) - male
FCC, RoHS
3-year warranty
DisplayPort cable
Latched
Length
4.57 m
Connector
20 pin DisplayPort - male
FCC, RoHS
3-year warranty
92P9 StarTech.com DisplayPort to VGA Video Adapter Converter In Stock £24.40
92P9 StarTech.com DisplayPort to VGA Video Adapter Converter In Stock £16.02
92P9 StarTech.com 6 ft Mini DisplayPort to VGA Adapter Converter Cable – mDP to VGA 1920x1200 - Black In Stock £20.53
92P9 StarTech.com 3 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black In Stock £19.83
92P9 StarTech.com 6 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black In Stock £21.98
92P9 StarTech.com 15 ft Mini DisplayPort to VGA Adapter Converter Cable – mDP to VGA 1920x1200 - Black In Stock £23.34
92P9 StarTech.com 10 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black In Stock £23.68
92P9 StarTech.com 15 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black In Stock £6.99
92P9 StarTech.com DisplayPort 1.2 to VGA Adapter Converter – DP to VGA – 1920x1200 In Stock £16.13
92P9 StarTech.com DP to VGA Adapter with Audio In Stock £6.96
92P9 StarTech.com DisplayPort to VGA Adapter - 1920x1200 In Stock £70.60
Length: 4.57m
