StarTech.com 15 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black
Quicklinx: 92P9WS00 Mfr#: DP2VGAMM15B
Hurry, only 1 left in stock!
£25.48 ex VAT
£30.57 inc VAT
Connect a DisplayPort-equipped PC to a VGA monitor/projector, with a 15ft long cable. The DP2VGAMM15B 15ft active DisplayPort to VGA converter cable lets you connect your DisplayPort-equipped desktop or laptop directly to a VGA monitor or projector at a longer distance than a standard-length cable would support, while saving the expense of additional adapters.
Plus, because the converter cable supports video resolutions up to 1920x1200 you can convert a DisplayPort video source to VGA without sacrificing video quality.
StarTech.com 15 ft DisplayPort to VGA Adapter Cable - DP to VGA Video Converter - Active DisplayPort to VGA Cable for PC 1920x1200 - Black (DP2VGAMM15B) - DisplayPort cable - 4.57 m
DisplayPort cable
Latched
Length
4.57 m
Connector
DisplayPort - male
Connector (Second End)
HD-15 (VGA) - male
FCC, RoHS
3-year warranty
DisplayPort cable
Latched
Length
4.57 m
Connector
20 pin DisplayPort - male
FCC, RoHS
3-year warranty
