Create high-resolution 4K x 2K connections with HBR2 support between your DisplayPort equipped devices. This DisplayPort cable provides a secure connection between your DisplayPort equipped devices and is capable of providing higher performance than either HDMI or dual-link DVI.
The DP cable supports high resolutions of up to 4K x 2K (4096 x 2160, 60Hz) with a maximum HBR2 bandwidth of 21.6Gbps, as well as optional audio support. The cable also supports Multi-Stream Transport (MST) for daisy chaining multiple monitors.
The 6-foot cable is DisplayPort (VESA) certified to support DP 1.2 specifications and ensure a high-quality, reliable connection for all of your DisplayPort devices.
High-performance cable
This 6ft (2m) VESA-certified DisplayPort v1.2 cable supports 4K x 2K, 21.6Gbps bandwidth, HBR2, 8Ch Audio, Multi-Stream Transport (MST), GTC for precise audio channel timing and 3D Stereo. -
Reliable design
Durable ABS connectors with flexible PVC strain relief and jacket prevent fraying/damage due to bending or rough usage. Metal connector sub-structure provides EMI shielding. Latching DP connectors prevent accidental disconnection. -
Quality construction
28AWG wire with gold-plated connectors for improved signal integrity and reliability. Superior EMI shielding with Al-Mylar foil and copper braid provides higher quality video and audio. Backwards compatible with DP 1.1. -
Applications
Ideal for home/offices/boardrooms/conference rooms/classrooms, works with your professional workstations. Use with 1080p/UHD/4K monitors, projector or large display.
- StarTech.com DisplayPort 1.2 Cable w/ Latches - 6ft / 2m - HBR2 - 4K x 2K Display - Certified DP to DP Video Cable M/M (DISPLPORT6L) - DisplayPort cable - 1.8 m
- DisplayPort cable
- Technology
- Shielded
- Latched
- Length
- 1.8 m
- Connector
- DisplayPort - male
- Connector (Second End)
- Black
- Limited lifetime warranty
- Designed For
- P/N: BOX4HDECP2, CDP2DP14B, CDP2DPHD, CDP2DPVGA, DK30C2DPEP, DK30C2DPEPUE, DK30C2DPPD, DK30C2DPPDUE, DK30CH2DEP, DK30CH2DEPUE, DK31C3HDPD, DK31C3HDPDUE, DKM30CHDPD, DKM30CHDPDUE, KITBXAVHDPEU, KITBXAVHDPNA, KITBXAVHDPUK, MOD4AVHD, MOD4AVHDBT, MST14DP123DP, SV211DPUA4K, SV231DPU34K, TB32DP14
- DisplayPort cable
- Technology
- Shielded
- Shielding Material
- Aluminum mylar foil with braid
- American Wire Gauge (AWG)
- 30
- Plated Connector
- Nickel
- Latched
- Length
- 1.8 m
- Black
- Connector
- 20 pin DisplayPort - male
- Designed For
- P/N: BOX4CABLE, BOX4HDECP2, CDP2DP, CDP2DP14B, CDP2DPHD, CDP2DPUCP, CDP2DPVGA, CDP2DPW, DK30A2DH, DK30C2DPEP, DK30C2DPEPUE, DK30C2DPPD, DK30C2DPPDUE, DK30CH2DEP, DK30CH2DEPUE, DK30CH2DPPD, DK30CHDDPPD, DK31C3HDPD, DK31C3HDPDUE, DKM30CHDPD, DKM30CHDPDUE, DKWG30DPHPD, DKWG30DPHPDU, DPBOOST, DPPNLFM3, DPPNLFM3PW, DVI2DP2, GCMDP2DPMF, HD2DP, HD2DPVGADVI, HDMI2DP, HDVGADP2HD, KITBXAVHDPEU, KITBXAVHDPNA, KITBXAVHDPUK, MDP2DPDVHD, MDP2DPMF6IN, MOD4AVHD, MOD4AVHDBT, MST14DP123DP, MST30C2DPPD, MST30C2HDPPD, MSTDP122DP, MSTDP123DP, MSTDP124DP, MSTMDP122DP, MSTMDP123DP, MSTMDP124DP, SP123DP, ST121HDBTSC, STDHVHDBT, SV211DPUA, SV211DPUA4K, SV231DPDDUA, SV231DPDDUA2, SV231DPU, SV231DPU34K, SV231DPUA, SV431DPDDUA2, SV431DPU3A2, SV431DPUA, SV431DPUA2, TB2DOCK4K2DP, TB32DP14, TB32DP2, TB32DP2T, TB3DK2DHV, TB3DK2DHVUE, TB3DK2DPPD, TB3DK2DPPDUE, TB3DK2DPW, TB3DK2DPWUE, TB3DKDPMAW, TB3DKDPMAWUE, USB32DP24K60, USB32DP4K, USB32DPES2, USB32DPPRO, USB3DDOCKFT, USB3DOCKH2DP, USB3DOCKHDPC, USB3VDOCK4DP
StarTech.com 3ft DisplayPort Panel Mount Cable - F/M | In Stock | £13.14 |
StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k | In Stock | £14.12 |
StarTech.com Mini DisplayPort to DisplayPort Adapter Converter - M/F | In Stock | £13.66 |
StarTech.com 6in Mini DisplayPort to DisplayPort Video Cable Adapter - M/F | In Stock | £15.74 |
StarTech.com 1m (3 ft) White Mini DisplayPort 1.2 Cable M/M - Mini DisplayPort 4k | In Stock | £14.48 |
StarTech.com 2m (6 ft) White Mini DisplayPort 1.2 Cable M/M - Mini DisplayPort 4k | In Stock | £5.85 |
