Connect high resolution VGA video, USB, audio and microphone all in one cable. The USBVGA4N1A6 6 ft 4-in-1 USB VGA KVM Switch Cable with Audio and Microphone provides VGA video, USB mouse and keyboard, 3.5mm audio, and 3.5mm microphone connections, all in a single, compact cable.
- StarTech.com 6 ft 4-in-1 USB VGA KVM Switch Cable with Audio and Microphone - VGA KVM Cable - USB KVM Cable - KVM Switch Cable (USBVGA4N1A6) - keyboard / mouse / video / audio cable - 1.8 m
- Keyboard / mouse / video / audio cable
- Length
- 1.8 m
- Connectors
- 15 pin HD D-Sub (HD-15) - male , 4 pin USB Type A - male , 2 x mini-phone stereo 3.5 mm - male
- Connectors (Second End)
- 15 pin HD D-Sub (HD-15) - male , 4 pin USB Type B - male , 2 x mini-phone stereo 3.5 mm - male
- Limited lifetime warranty
- Designed For
- P/N: SV231DDUSB, SV231DVGAU2A, SV431DDUSB
- Length
- 1.8 m
- Connectors
- UL, RoHS
- Designed For
StarTech.com 6 ft 2-in-1 USB KVM Cable | In Stock | £7.04 |
StarTech.com 4 Port Rack Mountable USB KVM Switch with Audio & USB Hub | In Stock | £89.50 |
StarTech.com 4 Port DVI VGA Dual Monitor KVM Switch USB with Audio & USB 2.0 Hub | In Stock | £243.20 |
StarTech.com 2 Port DVI VGA Dual Monitor KVM Switch USB with Audio & USB 2.0 Hub | In Stock | £74.93 |
StarTech.com 6 ft 4-in-1 USB VGA KVM Switch Cable with Audio and Microphone | In Stock | £8.11 |
