StarTech.com 6 ft 2-in-1 USB KVM Cable
Quicklinx: 3ZNYWS00 Mfr#: SVUSB2N1_6
13 In Stock
£7.01 ex VAT
£8.41 inc VAT
StarTech.com's universal series USB KVM switch cables prevent tangles and keep your workspace neat while delivering excellent performance with your StarTech.com StarView or other KVM switch. This 6ft 2-in-1 USB + VGA KVM switch cable is constructed of high quality materials and is expertly designed to ensure crystal clear display quality, and durable performance.
  • Versatile connectivity
    The cable features a combination of 15 pin HD D-Sub and USB connectors, accommodating various devices and ensuring compatibility with multiple systems.
  • Robust adapter design
    With male and female connector genders, this cable is designed for easy Plug-and-Play functionality, allowing for quick setup and configuration.
  • Durable construction
    Built with quality materials, the cable is designed to withstand regular use, ensuring reliable performance over time.
StarTech.com 2-in-1 USB KVM Cable - Keyboard / video / mouse / USB cable - HD-15 (VGA), USB Type B (M) to USB, HD-15 (VGA) - 6 ft - SVUSB2N1_6 - keyboard / video / mouse / USB cable - 1.8 m
Length
1.8 m
Connectors
4 pin USB Type B - male , 15 pin HD D-Sub (HD-15) - female
Connectors (Second End)
4 pin USB Type A - male , 15 pin HD D-Sub (HD-15) - male
P/N: RKCOND17HD, SV231USBGB, SV231USBLC, SV431, SV431H, SV431USB, SV431USBAE, SV431USBAEGB, SV431USBDDM
Length
1.8 m
Connectors
3ZNY StarTech.com 6 ft 2-in-1 USB KVM Cable In Stock £7.01
3ZNY StarTech.com 10 ft 2-in-1 Universal USB KVM Cable In Stock £10.74
3ZNY StarTech.com 10 ft Ultra Thin USB VGA 2-in-1 KVM Cable In Stock £9.44
3ZNY StarTech.com 2 Port Professional USB KVM Switch Kit with Cables In Stock £60.78
3ZNY StarTech.com 4 Port Professional VGA USB KVM Switch with Hub In Stock £81.83
3ZNY StarTech.com 4 Port Rack Mountable USB KVM Switch with Audio & USB Hub In Stock £62.79
3ZNY StarTech.com 15 ft 2-in-1 Universal USB KVM Cable In Stock £14.71
3ZNY StarTech.com 6 ft 4-in-1 USB VGA KVM Switch Cable with Audio and Microphone In Stock £6.48
3ZNY StarTech.com 1m Black SuperSpeed USB 3.0 Extension Cable A to A - M/F In Stock £6.74
3ZNY StarTech.com 2m Black SuperSpeed USB 3.0 Extension Cable A to A - M/F In Stock £6.94
