Extend your SuperSpeed USB 3.0 cable by up to an additional 2 meters. The USB3SEXT2MBK 2mBlack SuperSpeed USB 3.0 extension cable (A-A), offers a durable, high-quality connection that harnesses the full capability of the USB 3.0 standard.
This USB 3.0 male-to-female cable extends a USB 3.0 cable connection by up to 2 meters and delivers the full USB 3.0 bandwidth of 5Gbps, supporting maximum throughput between compatible devices when used with a USB 3.0 host and device.
The USB 3.0 extension cord features high-quality Shielded Twisted Pair (STP) construction, helping to prevent electromagnetic interference and ensuring reliable data communication.
Robust Connectivity
Featuring a 9-pin USB Type-A male connector on one end and a female connector on the other, this cable provides a strong and reliable connection for your devices. -
High-Speed Performance
Designed in accordance with USB 3.0 specifications, this extension cable supports data transfer speeds essential for efficient operations. -
Durability and Reliability
Constructed with a durable design and nickel-plated connectors, this cable is built to last and ensures ongoing reliability in your connections. -
Versatile Usability
Suitable for connecting a variety of USB devices, this extension cable is perfect for both personal and professional environments. -
Easy Organization
The 2 m length allows for neat organization of your workspace, preventing cables from cluttering your area.
- StarTech.com 2m Black SuperSpeed USB 3.0 Extension Cable A to A - Male to Female USB 3.0 Extender Cable - USB 3.0 Extension Cord - 2 meter (USB3SEXT2MBK) - USB extension cable - USB Type A to USB Type A - 2 m
- Technology
- Shielded foiled twisted pair (SFTP)
- Length
- 2 m
- Connector
- 9 pin USB Type A - female
- Connector (Second End)
- 9 pin USB Type A - male
- USB 3.0
- Black
- Limited lifetime warranty
- Designed For
- P/N: CFASTRWU3, HB30A4AIB, HB30C4AIB, HB31C4AB, ST43004UA, ST4300MINI, SV1631DUSBUK, SV211DPUA, SV211DPUA4K, SV211HDUA4K, SVUSB2N1_6, USB2001EXT2, USB2001EXT2NA, USB2002EXT2NA, USB2004EXT2, USB2004EXT2NA, USB3SAA3MBK
- Technology
- American Wire Gauge (AWG)
- 24/28
- Plated Connector
- Nickel
- Length
- 2 m
- Black
- Connector
- USB 3.0, RoHS
- Designed For
StarTech.com 5 ft Desktop SuperSpeed USB 3.0 Extension Cable - A to A M/F | In Stock | £11.51 |
StarTech.com 1m Blue SuperSpeed USB 3.0 Extension Cable A to A - M/F | In Stock | £6.58 |
StarTech.com 1m Black SuperSpeed USB 3.0 Extension Cable A to A - M/F | In Stock | £6.51 |
StarTech.com 2m Black SuperSpeed USB 3.0 Extension Cable A to A - M/F | In Stock | £6.94 |
StarTech.com 6in USB 3.0 Extension Cable | In Stock | £5.45 |
StarTech.com 3m 10ft USB 3.0 A to A Cable | In Stock | £7.87 |
