StarTech.com's universal series USB KVM switch cables prevent tangles and keep your workspace neat while delivering excellent performance with your StarTech.com StarView or other KVM switch. This 6ft 2-in-1 USB + VGA KVM switch cable is constructed of high quality materials and is expertly designed to ensure crystal clear display quality, and durable performance.
Versatile connectivity
The cable features a combination of 15 pin HD D-Sub and USB connectors, accommodating various devices and ensuring compatibility with multiple systems. -
Robust adapter design
With male and female connector genders, this cable is designed for easy Plug-and-Play functionality, allowing for quick setup and configuration. -
Durable construction
Built with quality materials, the cable is designed to withstand regular use, ensuring reliable performance over time.
- StarTech.com 2-in-1 USB KVM Cable - Keyboard / video / mouse / USB cable - HD-15 (VGA), USB Type B (M) to USB, HD-15 (VGA) - 6 ft - SVUSB2N1_6 - keyboard / video / mouse / USB cable - 1.8 m
- Length
- 1.8 m
- Connectors
- 4 pin USB Type B - male , 15 pin HD D-Sub (HD-15) - female
- Connectors (Second End)
- 4 pin USB Type A - male , 15 pin HD D-Sub (HD-15) - male
- Limited lifetime warranty
- Designed For
- P/N: RKCOND17HD, SV231USBGB, SV231USBLC, SV431, SV431H, SV431USB, SV431USBAE, SV431USBAEGB, SV431USBDDM
- Length
- 1.8 m
- Connectors
- Designed For
StarTech.com 6 ft 2-in-1 USB KVM Cable | In Stock | £7.04 |
StarTech.com 10 ft 2-in-1 Universal USB KVM Cable | In Stock | £10.74 |
StarTech.com 10 ft Ultra Thin USB VGA 2-in-1 KVM Cable | In Stock | £9.24 |
StarTech.com 2 Port Professional USB KVM Switch Kit with Cables | In Stock | £60.78 |
StarTech.com 4 Port Professional VGA USB KVM Switch with Hub | In Stock | £81.83 |
StarTech.com 15 ft 2-in-1 Universal USB KVM Cable | In Stock | £14.71 |
StarTech.com 6 ft 4-in-1 USB VGA KVM Switch Cable with Audio and Microphone | In Stock | £6.48 |
StarTech.com 1m Black SuperSpeed USB 3.0 Extension Cable A to A - M/F | In Stock | £6.73 |
StarTech.com 2m Black SuperSpeed USB 3.0 Extension Cable A to A - M/F | In Stock | £7.23 |
