StarTech.com 6.6ft USB C to DP 1.2 Cable
Quicklinx: J7TVWS00 Mfr#: CDP2DP2MBW
23 In Stock
£31.29 ex VAT
£37.54 inc VAT
This USB-C to DisplayPort 1.2 cable lets you connect your USB Type-C (or Thunderbolt 3) device to a DisplayPort display, or a DP device to a USB-C display with just one cable. At 6.6 ft. (2m) in length, this bidirectional adapter cable delivers a direct connection that eliminates excess adapters and cabling, ensuring a tidy, professional installation. For shorter installations, we also offer a 3.3 ft. (1m) USB-C to DP cable, enabling you to choose the right cable length for your custom installation needs. As well, the cable works with both Mac and Windows devices and allows for plug-and-play installation, removing the need for any additional software or drivers. Use this USB-C to DisplayPort adapter cable to output 4K video and audio to a DP display from the USB Type-C (or Thunderbolt 3) port on your laptop or mobile device. With bi-directional capabilities, this cable can also connect your DisplayPort-enabled devices to a display featuring USB-C input. This USB-C to DP 1.2 adapter cable lets you harness the video capabilities that are built into your computer's USB Type-C (or DisplayPort) connection, to deliver the astonishing quality of UHD to your 4K display. For even higher resolution and bandwidth support, we offer a USB-C to DP 1.4 cable, which is the perfect accessory for early adopters of 8K. CDP2DP2MBW is backed by a StarTech.com 3-year warranty and free lifetime technical support.
Note: Your USB 3.1 Type-C device must support DP Alt Mode to work with this cable.
  • Easy & Clutter-Free Installation
    At 6.6ft (2m) in length, this?bidirectional adapter cable delivers a direct?connection that eliminates excess adapters and cabling,?ensuring?a tidy, professional installation. For shorter installations, we also offer a 3.3 ft. (1 m) USB-C?to DP?cable, enabling you to choose the right cable length for your custom installation needs. As well, the cable works with?both?Mac and Windows devices and?allows for?plug-and-play installation, removing the need for any additional software or drivers.
  • Convenient, Bi-Directional Support
  • Ultra HD 4K Resolution at 60Hz
    This USB-C to DP 1.2 adapter cable lets you harness the video capabilities that are built into your computer's USB Type-C (or DisplayPort) connection, to deliver the astonishing quality of UHD to your 4K display. Note: Your USB 3.1 Type-C device must support DP Alt Mode to work with this cable.
StarTech.com 6.6ft (2m) USB C to DisplayPort 1.2 Cable, Bidirectional - DisplayPort cable - 24 pin USB-C to DisplayPort - 1.9 m
DisplayPort cable
4K60Hz support, bi-directional, active cable, 21.6 Gbps data rate, HBR2 support, HDR support, DisplayPort Alt mode, 7.1 audio channel support, plastic housing
Length
1.9 m
Connector
24 pin USB-C - male
Connector (Second End)
20 pin DisplayPort - male
Displayport 1.2/Thunderbolt
White
3-year warranty
DisplayPort cable
Length
1.9 m
White
78 g
Connector
24 pin USB-C - male
Displayport 1.2/Thunderbolt, FCC, HDCP 1.4, HDCP 2.2
Shipping Width
22 cm
Shipping Depth
12.8 cm
Shipping Height
1.8 cm
Shipping Weight
84 g
3-year warranty
