StarTech.com 6in Mini DisplayPort to DisplayPort Video Cable Adapter - M/F
Quicklinx: 7NZKWS00 Mfr#: MDP2DPMF6IN
Length: 15.2cm
More than 50 In Stock
£8.20 ex VAT
£9.84 inc VAT
Connect your DisplayPort monitor to a standard Mini DisplayPort source.
The MDP2DPMF6IN Mini DisplayPort to DisplayPort video cable adapter allows you to add a standard DisplayPort connection port to your existing mini Displayport equipped laptop. Easy to use and install, this cost-effective solution makes it easy for you to go from Mini DP to DP, in order to get the most from your Mini DisplayPort device.
  • Versatile connectivity
    This adapter allows seamless connection between devices with Mini DisplayPort outputs and displays that have a 20 pin DisplayPort input, providing flexibility for various setup configurations.
  • Durable construction
    Constructed with high-quality PVC shielding to protect against wear and ensure consistent performance over the lifespan of the cable, making it suitable for everyday use.
StarTech.com 6in Mini DisplayPort to DisplayPort Video Cable Adapter (MDP2DPMF6IN) - DisplayPort cable - 15.2 cm
DisplayPort cable
Length
15.2 cm
Connector
Mini DisplayPort - male
Connector (Second End)
DisplayPort - female
RoHS
P/N: CDP2DP141MB, CDP2DP146B, CDP2DPMM1MB, CDP2DPMM6B, DISPLPORT10L, DISPLPORT15L, DISPLPORT3L, DISPLPORT6L
DisplayPort cable
Shielding Material
PVC
American Wire Gauge (AWG)
32
Length
15.2 cm
Connector
20 pin DisplayPort - female
RoHS
7NZK StarTech.com 6 ft Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £9.00
7NZK StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £13.35
7NZK StarTech.com 6in Mini DisplayPort to DisplayPort Video Cable Adapter - M/F In Stock £8.20
7NZK StarTech.com 1m (3 ft) White Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £3.73
7NZK StarTech.com 2m (6 ft) White Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £12.14
7NZK StarTech.com 6 ft DisplayPort Cable with Latches - M/M In Stock £11.54
Length: 15.2cm
