StarTech.com 5m USB 2.0 Active Extension Cable - M/F
Quicklinx: 9J4BWS00 Mfr#: USB2AAEXT5M
Length: 5m
12 In Stock
£38.41 ex VAT
£46.09 inc VAT
The USB2AAEXT5M 5m Active USB 2.0 Extension Cable offers one USB-A male connector and one USB-A female connector, and provides an active extension of USB 2.0 devices of up to 5-meters (15-feet).
An all-in-one cable for overcoming distance restrictions as well as power source limitations, the active USB 2.0 extension cable incorporates bus-powered active circuitry to ensure performance beyond the length limits of standard USB cables. Plus you can daisy chain 4 cables for a total USB extension of up to 20-meters.
If necessary, the cable can be powered from a wall outlet using the Universal AC power adapter that was provided with the cable - this will allow you to use USB bus-powered devices that may require extra power.
The USB2AAEXT5M repeater cable supports the full USB 2.0 bandwidth of 480 Mbps.
StarTech.com 5m USB 2.0 Active Extension Cable M/F - 5 meter USB A Male to USB A Female USB 2.0 Repeater / Extender Cable - Black - 15ft (USB2AAEXT5M) - USB extension cable - USB to USB - 5 m
USB extension cable
Shielded
Active cable (signal regeneration), LED power indicator
Length
5 m
Connector
4 pin USB Type A - female
Connector (Second End)
4 pin USB Type A - male
USB / USB 2.0
P/N: LTUB1MBK, SVA5H2NEUA, UUSBOTG
USB extension cable
Shielded
Plated Connector
Nickel
Length
5 m
Connector
USB / USB 2.0, Plug and Play, FCC, RoHS
9J4B StarTech.com 10ft USB 2.0 Extension Cable A to A - M/F In Stock £5.02
9J4B StarTech.com 3 ft Black USB 2.0 Extension Cable A to A - M/F In Stock £4.20
9J4B StarTech.com 6 ft Black USB 2.0 Extension Cable A to A - M/F In Stock £4.33
9J4B StarTech.com 20m USB 2.0 Active Extension Cable - M/F In Stock £88.50
9J4B StarTech.com 15m USB 2.0 Active Extension Cable - M/F In Stock £62.30
9J4B StarTech.com 1m (3ft) White Apple 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad In Stock £14.63
9J4B StarTech.com 10m USB 2.0 Active Extension Cable - M/F In Stock £53.76
Length: 5m
