Connect USB 2.0 peripherals to your computer. The USB2HAB5M 5-meter USB A-to-B cable features one USB ''A'' male connector and one USB ''B'' male connector, providing a high quality connection to USB 2.0 peripherals such as USB printers, scanners or external USB hard drives.
Reliable connectivity
This cable ensures stable connections thanks to its quality build and 5 m length, making it suitable for various environments. -
Efficient data transfer
Compliant with USB 2.0 standards, this cable allows for fast and effective data transmission between connected devices. -
Shielded design
The shielded technology reduces interference, helping to maintain signal integrity for clearer data flow. -
Versatile use
With a 4-pin USB Type-A and a 4-pin USB Type-B connector, this cable is perfect for connecting multiple types of devices, including printers and external drives. -
Durable construction
Constructed with 24/28 AWG wires, the cable is designed for longevity, providing reliable service over time.
- StarTech.com 5m USB 2.0 A to B Cable M/M - USB cable - USB to USB Type B - 5 m
- USB cable
- Technology
- Shielded
- Length
- 5 m
- Connector
- 4 pin USB Type A - male
- Connector (Second End)
- 4 pin USB Type B - male
- USB / USB 2.0
- Black
- Limited lifetime warranty
- USB cable
- Technology
- Shielded
- American Wire Gauge (AWG)
- 24/28
- Length
- 5 m
- Black
- Connector
- USB / USB 2.0, RoHS
StarTech.com 1m USB 2.0 A to B Cable - M/M | In Stock | £3.90 |
StarTech.com 2m USB 2.0 A to B Cable - M/M | In Stock | £3.99 |
StarTech.com 3m USB 2.0 A to B Cable - M/M | In Stock | £4.51 |
StarTech.com 0.5m USB 2.0 A to B Cable - M/M | In Stock | £3.22 |
StarTech.com 5m USB 2.0 A to B Cable - M/M | In Stock | £5.75 |
