Connect USB 2.0 peripherals to your computer
The USB2HAB50CM 0.5-meter USB A-to-B cable features one USB ''A'' male connector and one USB ''B'' male connector, providing a high quality connection to USB 2.0 peripherals such as USB printers, scanners or external USB hard drives. Constructed of only top quality materials and expertly designed for durability, this USB 2.0 A-B cable is backed by StarTech.com''s Lifetime Warranty.
The StarTech.com Advantage
- Short cable length provides maximum portability, making this an easy solution to store in a laptop bag or carrying case
- Durable design, with high quality USB connectors
- Backed by StarTech.com lifetime warranty
Reliable connectivity
The 0.5 m USB 2.0 A to B Cable features male connectors on both ends, allowing for a secure connection between devices such as printers, scanners, and other peripherals. -
High-speed data transfer
Designed to support USB 2.0 standards, this cable ensures efficient data rates for seamless transfers, making it suitable for both professional and personal use. -
Quality design
With 24 AWG for power and 28 AWG for data, this cable is crafted to withstand regular use while providing performance and durability. -
Environmental compliance
The cable meets RoHS standards, ensuring it is free from hazardous materials, thereby promoting a safer environment.
- StarTech.com 0.5m USB 2.0 A to B Cable M/M - USB cable - USB to USB Type B - 50 cm
- USB cable
- Length
- 50 cm
- Connector
- 4 pin USB Type A - male
- Connector (Second End)
- 4 pin USB Type B - male
- USB / USB 2.0
- Black
- Limited lifetime warranty
- USB cable
- American Wire Gauge (AWG)
- 24/28
- Length
- 50 cm
- Black
- Connector
- USB / USB 2.0, RoHS
StarTech.com 1m USB 2.0 A to B Cable - M/M | In Stock | £3.71 |
StarTech.com 2m USB 2.0 A to B Cable - M/M | In Stock | £3.84 |
StarTech.com 3m USB 2.0 A to B Cable - M/M | In Stock | £4.51 |
StarTech.com 0.5m USB 2.0 A to B Cable - M/M | In Stock | £3.24 |
StarTech.com 5m USB 2.0 A to B Cable - M/M | In Stock | £5.75 |
