Create high-resolution 4k x 2k connections with HBR2 support between your DisplayPort-equipped devices over longer distances. The DISPL5M DisplayPort 1.2 Cable with latches provides a secure between your DisplayPort-equipped devices and allows for a connection distance of up to 5-meters between your source and display.
The DP cable is capable of providing higher performance than either HDMI or dual link DVI with support for high resolutions of up to 4k x 2k (3840 x 2160) @ 60Hz and a maximum HBR2 bandwidth of 21.6 Gbps. The cable also supports Multi-Stream (MST) for daisy chaining multiple monitors and provides optional audio support.
The DISPL5M long DisplayPort cable ensures that digitally protected content is displayed properly, with both HDCP and DPCP capability.
Reliable shielding technology
The cable features a shielded design that combines aluminum mylar foil with braid, effectively minimizing interference and ensuring a stable signal throughout its length. -
High-resolution compatibility
This DisplayPort cable supports resolutions up to 4K, providing sharp clarity and vibrant colors for an outstanding viewing experience. -
Durable construction
Constructed with a robust design, including a nickel-plated connector, this cable can withstand frequent use while maintaining connection integrity. -
Secure connections with latches
The cable is equipped with latched connectors that ensure a firm connection, preventing accidental disconnections during operation. -
Environmentally compliant design
This cable meets RoHS standards, making it an eco-friendly choice for consumers concerned about environmental impact.
- StarTech.com 5m Long DisplayPort 1.2 Cable with Latches DisplayPort 4k - DisplayPort cable - 5 m
- DisplayPort cable
- Technology
- Shielded
- Latched
- Length
- 5 m
- Connector
- DisplayPort - male
- Connector (Second End)
- RoHS
- Black
- Limited lifetime warranty
- DisplayPort cable
- Technology
- Shielded
- Shielding Material
- Aluminum mylar foil with braid
- American Wire Gauge (AWG)
- 28
- Plated Connector
- Nickel
- Latched
- Length
- 5 m
- Black
- Connector
- 20 pin DisplayPort - male
- RoHS
StarTech.com 5m Long DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k | In Stock | £16.94 |
StarTech.com 2m DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k | In Stock | £9.57 |
StarTech.com 1m DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k | In Stock | £5.83 |
StarTech.com 3m DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k | In Stock | £15.35 |
StarTech.com 7m DisplayPort Cable with Latches - M/M | In Stock | £11.82 |
