Connect DisplayPort-equipped devices over longer distances. The DISPL7M DisplayPort Cable with latches provides a secure connection between your DisplayPort-enabled devices and allows for a connection distance of up to 7 meters between your source and display.
With a bandwidth of 10.8Gbps and support for maximum resolutions up to 2560x1600 (WQXGA), as well as optional audio support, this 7-meter DisplayPort cable offers impressive video capability and ensures that digitally protected content is displayed properly, with both HDCP and DPCP capability.
Durable construction
The cable is made with shielding material consisting of aluminum mylar foil with braid, ensuring durability and effective signal integrity. -
Secure latching mechanism
The latched connectors prevent accidental disconnections and ensure a stable connection even in busy environments. -
Optimized for performance
With a 28 AWG rating, this DisplayPort cable supports high-speed data transfer, making it suitable for high-definition video and audio. -
Corrosion-resistant connectors
Nickel-plated connectors provide resistance to wear and tear while ensuring optimal conductivity and performance. -
Environmentally compliant
This cable meets RoHS standards, reflecting a commitment to using materials that are safer for the environment.
- StarTech.com 7m DisplayPort Cable with Latches M/M - DisplayPort cable - 7 m
- DisplayPort cable
- Technology
- Shielded
- Latched
- Length
- 7 m
- Connector
- DisplayPort - male
- Connector (Second End)
- RoHS
- Black
- Limited lifetime warranty
- DisplayPort cable
- Technology
- Shielded
- Shielding Material
- Aluminum mylar foil with braid
- American Wire Gauge (AWG)
- 28
- Plated Connector
- Nickel
- Latched
- Length
- 7 m
- Black
- Connector
- 20 pin DisplayPort - male
- RoHS
StarTech.com 5m Long DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k | In Stock | £16.94 |
StarTech.com 2m DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k | In Stock | £9.29 |
StarTech.com 1m DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k | In Stock | £5.85 |
StarTech.com 3m DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k | In Stock | £15.35 |
