StarTech.com 5m Long DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k
Quicklinx: 7RPNWS00 Mfr#: DISPL5M
Type: DisplayPort
Length: 5m
33 In Stock
£25.85 ex VAT
£31.02 inc VAT
Create high-resolution 4k x 2k connections with HBR2 support between your DisplayPort-equipped devices over longer distances. The DISPL5M DisplayPort 1.2 Cable with latches provides a secure between your DisplayPort-equipped devices and allows for a connection distance of up to 5-meters between your source and display.
The DP cable is capable of providing higher performance than either HDMI or dual link DVI with support for high resolutions of up to 4k x 2k (3840 x 2160) @ 60Hz and a maximum HBR2 bandwidth of 21.6 Gbps. The cable also supports Multi-Stream (MST) for daisy chaining multiple monitors and provides optional audio support.
The DISPL5M long DisplayPort cable ensures that digitally protected content is displayed properly, with both HDCP and DPCP capability.
StarTech.com 5m Long DisplayPort 1.2 Cable with Latches DisplayPort 4k - DisplayPort cable - 5 m
DisplayPort cable
Shielded
Latched
Length
5 m
Connector
DisplayPort - male
Connector (Second End)
DisplayPort - male
RoHS
DisplayPort cable
Shielded
Shielding Material
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Latched
Length
5 m
Connector
20 pin DisplayPort - male
RoHS
7RPN StarTech.com 3ft DisplayPort Panel Mount Cable - F/M In Stock £14.07
7RPN StarTech.com 5m Long DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £25.85
7RPN StarTech.com 2m DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £12.37
7RPN StarTech.com 1m DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £10.20
7RPN StarTech.com 3m DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £22.45
7RPN StarTech.com 7m DisplayPort Cable with Latches - M/M In Stock £59.32
Type: DisplayPort
Length: 5m
