Make Power-over-Ethernet-capable Gigabit network connections. The N6PATC5MBL Cat 6 Patch Cable (5m) meets or exceeds all Category 6 cable specifications to ensure reliable Gigabit network connections, and features a durable blue PVC jacket that enables you to color code your network cable runs as needed.
To ensure long-lasting performance, this high quality Cat 6 patch cable features a snagless design that protects the RJ45 connector clips from damage and makes the cable less prone to snagging during installation. The cable also features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles - reducing the risk of cable damage, which could decrease network performance.
Constructed of only top quality materials, this Cat 6 Patch Cord delivers reliable performance.
StarTech.com Cat6 cables are manufactured using high-quality copper conductors. While many cable manufacturers offer a "cheaper" cable based on a copper-coated aluminum core, StarTech.com makes no compromises on quality to ensure you receive top value and performance for your network cable investment.
This Cat6 cable is constructed with 24 gauge copper wire, to support a broad range of Ethernet applications such as Power over Ethernet (PoE). Because StarTech.com uses a high quality copper wire, these cables easily sustain the power required for Power over Ethernet applications, whereas the inferior quality offered by copper-coated aluminum cables may be subject to insufficient power delivery, heat buildup, equipment damage and potentially, fire.
This Cat 6 patch cable offers high quality connectors comprised of 50-micron gold, to deliver optimum conductivity while eliminating signal loss due to oxidation or corrosion.
- StarTech.com 5m CAT6 Ethernet Cable, 10 Gigabit Snagless RJ45 650MHz 100W PoE Patch Cord, CAT 6 10GbE UTP Network Cable w/Strain Relief, Blue, Fluke Tested/Wiring is UL Certified/TIA - Category 6 - 24AWG (N6PATC5MBL) - patch cable - 5 m - blue
- Patch cable - CAT 6
- Technology
- Wiring Scheme
- T568B
- Wires per Cable
- 8 wires
- Molded, snagless
- Length
- 5 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Blue
- Limited lifetime warranty
- Network Cable Type
- Technology
- Wiring Scheme
- T568B
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24
- Wires per Cable
- 8 wires
- Pairs per Cable
- 4 pairs
- Plated Connector
- Gold
- Molded, snagless
- Length
- 5 m
- Blue
- Connector
- RJ-45 - male
- RJ-45 - male
- RoHS, ETL, TIA/EIA-568-B - up to 500 MHz
StarTech.com 5m Blue Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £7.40 |
StarTech.com 5m Black Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £7.25 |
StarTech.com 5m Gray Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £8.22 |
StarTech.com 5m Orange Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £7.33 |
StarTech.com 5m Red Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £8.25 |
StarTech.com 5m Green Cat6 Patch Cable | In Stock | £7.42 |
StarTech.com 5m Yellow Cat6 Patch Cable | In Stock | £8.24 |
StarTech.com 5m Purple Cat6 Patch Cable | In Stock | £7.42 |
