StarTech.com N6PATC5MYL. Cable length: 5 m, Cable standard: Cat6, Connector 1: RJ-45. Weight: 180 g. Package width: 255 mm, Package depth: 330 mm, Package height: 40 mm
Durable construction
The PVC jacket provides protection against environmental factors while maintaining flexibility for easy routing. The stranded design allows for better performance, especially in environments where movement is required. -
High performance
With a tested frequency of 500 MHz, this Ethernet cable supports high-speed networking for gaming, streaming, and business applications, ensuring smooth and uninterrupted connectivity. -
Flexible connectivity
Each end of the cable is equipped with male RJ-45 connectors that facilitate connections to both devices and wall ports, providing a straightforward solution for networking needs.
- StarTech.com 5m CAT6 Ethernet Cable, 10 Gigabit Snagless RJ45 650MHz 100W PoE Patch Cord, CAT 6 10GbE UTP Network Cable w/Strain Relief, Yellow, Fluke Tested/Wiring is UL Certified/TIA - Category 6 - 24AWG (N6PATC5MYL) - network cable - 5 m - yellow
- Network cable - CAT 6
- Technology
- Wiring Scheme
- T568B
- Wires per Cable
- 8 wires
- Snagless, stranded, PoE ready
- Length
- 5 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Yellow
- Limited lifetime warranty
- Network Cable Type
- Technology
- Wiring Scheme
- T568B
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24
- Wires per Cable
- 8 wires
- Pairs per Cable
- 4 pairs
- Plated Connector
- Gold
- Length
- 5 m
- 180 g
- Yellow
- Connector
- RJ-45 - male
- RJ-45 - male
- RoHS, ETL, WEEE - up to 500 MHz
StarTech.com 5m Blue Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £7.36 |
StarTech.com 5m Black Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £7.84 |
StarTech.com 5m Gray Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £9.11 |
StarTech.com 5m Orange Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £7.93 |
StarTech.com 5m Red Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £7.84 |
StarTech.com 5m Green Cat6 Patch Cable | In Stock | £7.84 |
StarTech.com 5m Purple Cat6 Patch Cable | In Stock | £7.84 |
