StarTech.com 5m 16.4ft 40G QSFP+ DAC Cable
Quicklinx: D9VBWS00 Mfr#: QSFPH40GCU5M
Length: 5m
Colour: Black
£109.80 ex VAT
£131.76 inc VAT
Connect your Cisco 40GbE QSFP+ network devices with this cost-effective, passive Twinax copper cable. This 40G QSFP+ cable delivers what you need most in your network connections: reliable performance. It's built to MSA specifications and fully tested to ensure seamless compatibility.
This passive twinaxial cable is a fully hot-pluggable, direct-attach cable, supporting 40 Gigabit Ethernet applications connected through QSFP+ (Quad Small-Form Factor Pluggable) ports.
Designed for short-length, high-speed interconnects, this low-power, low-latency Twinax cable is a cost-effective alternative to fiber-optic cable assemblies, supporting short-distance applications such as point-to-point in-rack and across-rack network switch or server connections.
The QSFPH40GCU5M is a reliable replacement cable for the Cisco QSFP-H40G-CU5M.
StarTech.com Cisco QSFP-H40G-CU5M Compatible 5m 40G QSFP+ to QSFP+ DAC Twinax, 40GbE QSFP+ Copper DAC 40 Gbps Low Power Passive Transceiver Module DAC, Cisco Firepower C9200, QSFP+ Cable - Lifetime Warranty (QSFPH40GCU5M) - direct attach cable - 5 m - black
Direct attach cable - SFF-8436
Twinaxial
Shielding Material
Copper
Passive cable, Hot-pluggable
Length
5 m
Connector
QSFP+
Connector (Second End)
QSFP+
Network Cable Type
Twinaxial
Shielding Material
Copper
Jacket Material
PVC
American Wire Gauge (AWG)
28
Impedance
100 Ohm
Length
5 m
1.8 cm
1.3 cm
316 g
Connector
QSFP+
QSFP+
FCC, RoHS, WEEE, RCM
70 °C
Length: 5m
Colour: Black
