StarTech.com 50x10mm Replacement Ball Bearing Computer Case Fan TX3/LP4 Connector
Quicklinx: 76S9WS00 Mfr#: FAN5X1TX3
Type: Case Fan
Hurry, only 3 left in stock!
£5.66 ex VAT
£6.79 inc VAT
Overheating hardware can be a problem in most Server rooms. With StarTech.com's new LP4 Replacement Ball Bearing Fan, you can avoid problems to workstations. This fan exhausts hot air out of a PC, increasing dependability and extending component lifetime.
  • Efficient cooling performance
    Maintaining optimal cooling is essential for computer longevity, and this 50 mm fan effectively regulates temperatures within your case.
  • Quiet operation
    With a noise level of just 25 dB, the fan operates quietly, ensuring a more pleasant working or gaming environment.
  • Wide temperature tolerance
    Designed to function efficiently in a range of temperatures from -10°C to 80°C, making it suitable for various operating conditions.
  • Easy installation
    The fan comes with a TX3/LP4 connector, simplifying the installation process and making it accessible for users of all skill levels.
  • Durable construction
    Featuring a reliable ball bearing design, this fan is built to last, reducing the need for frequent replacements.
StarTech.com 50x10mm Replacement Ball Bearing Computer Case Fan TX3/LP4 Connector - 3 pin case Fan - TX3 Fan - 50mm Fan (FAN5X1TX3) - system fan kit
System fan kit
Fan Diameter
50 mm
Noise Level
25 dB
30 g
1-year warranty
System fan kit
30 g
Heatsink & Fan
Fan Diameter
50 mm
Noise Level
25 dB
Limited warranty: - 1 year
-10 °C
80 °C
76S9 StarTech.com LP4 to 2x LP4 Power Y Splitter Cable M/F In Stock £4.29
76S9 StarTech.com 60x10mm Replacement Ball Bearing Computer Case Fan with TX3 Connector In Stock £5.81
76S9 StarTech.com 6in TX3 Fan Power Splitter Cable In Stock £2.96
Type: Case Fan
