Connect two 3-pin (TX3) fans to a single power supply connector. The TX3SPLITTER 6in TX3 Fan Power Splitter Cable lets you connect two 3-pin (TX3) fans to a single power supply connector, allowing you to optimize your cooling capability without having to upgrade the power supply.
The 6 inch Y-Cable extends the length of the connection from the computer power supply, offering greater flexibility in positioning the fans within the system case.
- StarTech.com 6in TX3 Fan Power Splitter Cable - Fan power splitter - 3 pin internal power (F) to 3 pin internal power (M) - 5.9 in - TX3SPLITTER - fan power splitter - 3 PIN internal power to 3 PIN internal power - 15 cm
- Length
- 15 cm
- Connector
- 3 PIN internal power - female
- Connector (Second End)
- 2 x 3 PIN internal power - male
- Designed For
- P/N: FAN12025PWM, FAN5X1TX3, FAN8025PWM
- Length
- 15 cm
- Connector
- FCC
- Designed For
