Overheating hardware can be a problem in most Server rooms. With StarTech.com's new LP4 Replacement Ball Bearing Fan, you can avoid problems to workstations. This fan exhausts hot air out of a PC, increasing dependability and extending component lifetime.
Efficient cooling performance
Maintaining optimal cooling is essential for computer longevity, and this 50 mm fan effectively regulates temperatures within your case. -
Quiet operation
With a noise level of just 25 dB, the fan operates quietly, ensuring a more pleasant working or gaming environment. -
Wide temperature tolerance
Designed to function efficiently in a range of temperatures from -10°C to 80°C, making it suitable for various operating conditions. -
Easy installation
The fan comes with a TX3/LP4 connector, simplifying the installation process and making it accessible for users of all skill levels. -
Durable construction
Featuring a reliable ball bearing design, this fan is built to last, reducing the need for frequent replacements.
- StarTech.com 50x10mm Replacement Ball Bearing Computer Case Fan TX3/LP4 Connector - 3 pin case Fan - TX3 Fan - 50mm Fan (FAN5X1TX3) - system fan kit
- Product Type
- System fan kit
- Fan Diameter
- 50 mm
- Noise Level
- 25 dB
- 30 g
- 1-year warranty
- Product Type
- System fan kit
- 30 g
Heatsink & Fan
- Fan Diameter
- 50 mm
- Noise Level
- 25 dB
- Limited warranty: - 1 year
- -10 °C
- 80 °C
StarTech.com LP4 to 2x LP4 Power Y Splitter Cable M/F | In Stock | £4.52 |
StarTech.com 60x10mm Replacement Ball Bearing Computer Case Fan with TX3 Connector | In Stock | £5.81 |
StarTech.com 6in TX3 Fan Power Splitter Cable | In Stock | £4.24 |
