StarTech.com 5-Port USB PCIe Card
Quicklinx: GFHXWS00 Mfr#: PEXUSB312A1C1H
Wired / Wireless: Wired
Protocol: USB 2.0, SuperSpeed USB 3.0, USB 3.2 Gen 1, USB 3.1 + 1 more
Form Factor: Plug-in card
Compatibility: [N/A]
Type: USB adapter
20 In Stock
£48.96 ex VAT
£58.75 inc VAT
2x USB 3.2 Gen 2x1 (10Gbps) Type-A - 1x USB 3.2 Gen 2x1 (10Gbps) Type-C 2x1 - 2x USB 3.2 Gen 1x1 (5Gbps) IDC.
  • Work faster and prepare for the future
    This versatile PCI Express combo card leverages the performance potential of USB 3.2 Gen 2x1 (10Gbps) to help you work faster. The USB ports offer a data throughput of up to 10Gbps, so you can spend less time waiting for file transfers to complete or for access to your external peripherals.
  • Connect different types of USB devices
    Now you can easily add a variety of types and speeds (generations) of USB ports to your desktop or server, using a single adapter card. The card features: • One external USB-C port (10Gbps) • Two external USB-A ports (10Gbps) • One internal 20-pin IDC motherboard header port that can provide two internal USB-A ports (5Gbps) With a range of port types, the card lets you bridge the gap between devices that use different connectors. You can simultaneously connect and access USB Type-A and USB Type-C devices, while using only a single PCI Express expansion slot. By adding three types of USB ports in one combo card, you can free up space in your PC case, and eliminate the nuisance of having different cards for different USB devices.
  • Ideal for building or upgrading your computer
    With two internal motherboard-style headers, this dynamic USB 3.1 card is perfect for upgrading or building your own computer. If your existing headers are occupied, or if you don't have any motherboard headers, you can connect front panel hubs or card readers using this versatile alternative to costly motherboard or computer upgrades.
  • Connect your older USB devices
    Connecting your older peripherals isn't a problem. This 5-port USB 3.2 card is backward compatible with legacy USB 3.0, 2.0 and 1.1 devices, so you can eliminate the added expense and aggravation of purchasing new devices. PEXUSB312A1C1H is backed by a StarTech.com 2-year warranty and free lifetime technical support. Note: The card does not support DP alt mode or USB Power Delivery.
StarTech.com 5-Port USB PCIe Card, 10Gbps USB 3.1 Gen 2 PCIe Card w/ 1x USB-C & 2x USB-A, 1x 2 Port IDC (Internal 5Gbps USB Header Expansion), USB C PCIe Card, PCI Express USB Controller - Windows/macOS/Linux (PEXUSB312A1C1H) - USB adapter - PCIe 3.0 x4 - USB-C 3.1 Gen 2 x 2 + USB-C 3.2 Gen 2 x 1
USB adapter
Plug-in card
Interface (Bus) Type
PCI Express 3.0 x4
Ports
6.89 cm x 10.2 cm x 1.44 cm
60 g
USB 2.0, USB 3.0, USB 3.1, USB 3.2 Gen 2, USB 3.2 Gen 1
Data Transfer Rate
10 Gbps
ASMedia ASM1142
Red
Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Apple macOS High Sierra 10.13, Apple macOS Mojave 10.14, Microsoft Windows Server 2019, Linux LTS versions only, Linux 3.5 or later, Apple macOS Catalina 10.15, Apple macOS Big Sur 11.0, Apple macOS Monterey 12.0, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS Ventura 13.0
USB adapter
Plug-in card
PCI Express 3.0 x4
Ports
Wired
USB 2.0, SuperSpeed USB 3.0, USB 3.1, USB 3.2 Gen 2, USB 3.2 Gen 1
Data Transfer Rate
10 Gbps
UASP
Processor / Memory
ASMedia ASM1142
2 x USB 3.1 Gen 2 - 9 pin USB Type A , 1 x USB 3.2 Gen 2 - 24 pin USB-C , 1 x SATA power - 15 pin Serial ATA power (internal) , 1 x USB 3.0 - 20 pin IDC (internal)
Low-profile bracket
MTBF
1,677,495 hours
FCC, RoHS, WEEE, UASP (USB Attached SCSI Protocol)
Red
6.89 cm
10.2 cm
1.44 cm
60 g
Shipping Width
14.2 cm
Shipping Depth
17 cm
Shipping Height
3 cm
Shipping Weight
125 g
70 °C
15 - 90% (non-condensing)
GFHX StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter In Stock £5.06
GFHX StarTech.com 2 Port USB 3.0 A Female Slot Plate Adapter In Stock £18.98
GFHX StarTech.com USB 3.1 USB-C to USB-A Adapter In Stock £9.01
GFHX StarTech.com 1m USB 3.1 USB-C to USB-A Cbl In Stock £7.59
GFHX StarTech.com 1m USB 3.1 C to Micro-B Cable In Stock £10.24
GFHX StarTech.com StarTech.com 2-Port 10Gbps USB-A/USB-C PCIe Card -USB 3.1 In Stock £38.05
GFHX StarTech.com 2-Port USB 3.2 Gen 2 PCIe Card - USB-A SuperSpeed 10Gbps PCI Express 3.0 x2 In Stock £24.39
GFHX StarTech.com 4-Port USB 3.2 Gen 2 PCIe Card - USB-A SuperSpeed 10Gbps PCI Express 3.0 x4 In Stock £87.44
GFHX StarTech.com 1-Port USB 3.2 Gen 2x2 PCIe Card - USB-C SuperSpeed 20Gbps PCI Express 3.0 x4 In Stock £40.64
GFHX StarTech.com 4-Port USB PCIe Card In Stock £101.62
GFHX StarTech.com 5-Port USB PCIe Card, 10Gbps In Stock £56.66
GFHX StarTech.com 4-Port USB-A PCIe Card, 5Gbps In Stock £80.54
GFHX StarTech.com 4-Port USB-C 10Gb PCIe Card In Stock £201.91
GFHX StarTech.com 4-Port USB-C 10Gb PCIe Card In Stock £206.84
Protocol: USB 2.0
Protocol: SuperSpeed USB 3.0
Protocol: USB 3.2 Gen 1
Protocol: USB 3.1
Protocol: USB 3.2 Gen 2
Type: USB adapter
