StarTech.com 5-Port USB PCIe Card, 10Gbps
Quicklinx: HVMJWS00 Mfr#: PS4C3IA3-USB-C-CARD
£55.27 ex VAT
£66.32 inc VAT
Upgrade your computer's connectivity with the StarTech.com 5-Port USB PCIe Card. This USB 3.2 10 Gbps PCI Express Card features four USB-C external ports and one USB-A internal port, offering a wide range of connection possibilities for various devices. With support for USB 3.2 Gen 2, it delivers data transfer rates of up to 10 Gbps, enabling quick and efficient file transfers. Compatible with Windows, macOS, and Linux, this versatile USB PCIe controller card ensures broad operating system support. It also includes a 15-pin Serial ATA power connector, providing reliable power to connected devices. The card's plug-in form factor and PCI Express 3.0 compatibility make it an easy and effective upgrade to enhance your system's connectivity.
  • Enhanced connectivity
    Equipped with 4 external USB-C ports and 1 internal USB-A port, this PCIe card offers versatile connectivity options for a wide range of devices, ensuring you can connect multiple peripherals simultaneously.
  • High-speed data transfer
    With USB 3.2 Gen 2 support, experience rapid data transfer rates of up to 10 Gbps. This allows for quick file transfers and efficient operation, making it ideal for high-bandwidth devices.
  • Broad compatibility
    Designed to work seamlessly with Windows, macOS, and Linux, this USB PCIe controller card offers wide-ranging support, ensuring compatibility with a variety of operating systems.
  • Efficient power management
    The inclusion of a 15-pin Serial ATA power connector ensures that connected devices are adequately powered, providing reliable performance without the need for additional power sources.
  • Easy installation
    Thanks to its plug-in card form factor and compliance with PCI Express 3.0, this USB adapter is easy to install, making it a hassle-free upgrade to your system's connectivity capabilities.
StarTech.com 5-Port USB PCIe Card, USB 3.2 10Gbps, PCI Express Card with 4x USB-C Ports, 1x USB-A Internal Port, USB PCIe Controller Card, Windows/macOS/Linux - USB adapter - PCIe 3.0 x4 - USB-C 3.2 Gen 1 x 4 + USB 3.2 Gen 1 x 1
USB adapter
Plug-in card
Interface (Bus) Type
PCI Express 3.0 x4
PCI Specification Revision
PCIe 3.0
Ports
2.2 cm x 12.2 cm x 12.1 cm
60 g
USB 3.2 Gen 2
Data Transfer Rate
10 Gbps
ASMedia / VIA ASM3142 / VL822
USB 3.2 Gen 2
Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Apple macOS High Sierra 10.13, Apple macOS Mojave 10.14, Microsoft Windows Server 2019, Apple macOS Catalina 10.15, Apple macOS Big Sur 11.0, Microsoft Windows Server 2022, Apple macOS Monterey 12.0, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS Ventura 13.0, Linux 3.5.x or later LTS versions only, Apple macOS Sonoma 14.0
USB adapter
Plug-in card
PCI Express 3.0 x4
PCIe 3.0
Ports
Wired
USB 3.2 Gen 2
Data Transfer Rate
10 Gbps
UASP, bus powered
USB 3.2 Gen 2
Processor / Memory
4 x USB 3.2 Gen 2 - 24 pin USB-C (external) , 1 x USB 3.2 Gen 2 - 9 pin USB Type A (internal) , 1 x SATA power - 15 pin Serial ATA power (internal)
Low-profile bracket
RoHS, WEEE
2.2 cm
12.2 cm
12.1 cm
60 g
Shipping Width
3.5 cm
Shipping Depth
21 cm
Shipping Height
14.2 cm
Shipping Weight
156 g
50 °C
5 - 90% RH
HVMJ StarTech.com 0.5m USB 3.1 C - Micro B Cable In Stock £9.26
HVMJ StarTech.com 0.5m USB C Cable - USB 3.1 In Stock £12.46
HVMJ StarTech.com 1m 3ft USB 3.1 C to B Cable In Stock £15.26
HVMJ StarTech.com 3ft USB C Cable 10Gbps Gen2 In Stock £15.16
