2x USB 3.2 Gen 2x1 (10Gbps) Type-A - 1x USB 3.2 Gen 2x1 (10Gbps) Type-C 2x1 - 2x USB 3.2 Gen 1x1 (5Gbps) IDC.
Work faster and prepare for the future
This versatile PCI Express combo card leverages the performance potential of USB 3.2 Gen 2x1 (10Gbps) to help you work faster. The USB ports offer a data throughput of up to 10Gbps, so you can spend less time waiting for file transfers to complete or for access to your external peripherals. -
Connect different types of USB devices
Now you can easily add a variety of types and speeds (generations) of USB ports to your desktop or server, using a single adapter card. The card features: • One external USB-C port (10Gbps) • Two external USB-A ports (10Gbps) • One internal 20-pin IDC motherboard header port that can provide two internal USB-A ports (5Gbps) With a range of port types, the card lets you bridge the gap between devices that use different connectors. You can simultaneously connect and access USB Type-A and USB Type-C devices, while using only a single PCI Express expansion slot. By adding three types of USB ports in one combo card, you can free up space in your PC case, and eliminate the nuisance of having different cards for different USB devices. -
Ideal for building or upgrading your computer
With two internal motherboard-style headers, this dynamic USB 3.1 card is perfect for upgrading or building your own computer. If your existing headers are occupied, or if you don't have any motherboard headers, you can connect front panel hubs or card readers using this versatile alternative to costly motherboard or computer upgrades. -
Connect your older USB devices
Connecting your older peripherals isn't a problem. This 5-port USB 3.2 card is backward compatible with legacy USB 3.0, 2.0 and 1.1 devices, so you can eliminate the added expense and aggravation of purchasing new devices. PEXUSB312A1C1H is backed by a StarTech.com 2-year warranty and free lifetime technical support. Note: The card does not support DP alt mode or USB Power Delivery.
- Startech 5-Port USB PCIe Card, 10Gbps USB 3.1 Gen 2 PCIe Card w/ 1x USB-C & 2x USB-A, 1x 2 Port IDC (Internal 5Gbps USB Header Expansion), USB C PCIe Card, PCI Express USB Controller - Windows/macOS/Linux (PEXUSB312A1C1H) - USB adapter - PCIe 3.0 x4 - USB-C 3.1 Gen 2 x 2 + USB-C 3.2 Gen 2 x 1
- USB adapter
- Form Factor
- Plug-in card
- Interface (Bus) Type
- PCI Express 3.0 x4
- Ports
- 6.89 cm x 10.2 cm x 1.44 cm
- 60 g
- Data Link Protocol
- USB 2.0, USB 3.0, USB 3.1, USB 3.2 Gen 2, USB 3.2 Gen 1
- Data Transfer Rate
- 10 Gbps
- Processor
- ASMedia ASM1142
- Red
- System Requirements
- Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Apple macOS High Sierra 10.13, Apple macOS Mojave 10.14, Microsoft Windows Server 2019, Linux LTS versions only, Linux 3.5 or later, Apple macOS Catalina 10.15, Apple macOS Big Sur 11.0, Apple macOS Monterey 12.0, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS Ventura 13.0
- 2-year warranty
- USB adapter
- Form Factor
- Plug-in card
- Ports
- Connectivity Technology
- Wired
- USB 2.0, SuperSpeed USB 3.0, USB 3.1, USB 3.2 Gen 2, USB 3.2 Gen 1
- 10 Gbps
- UASP
Processor / Memory
- Processor
- ASMedia ASM1142
- 2 x USB 3.1 Gen 2 - 9 pin USB Type A , 1 x USB 3.2 Gen 2 - 24 pin USB-C , 1 x SATA power - 15 pin Serial ATA power (internal) , 1 x USB 3.0 - 20 pin IDC (internal)
- Included Accessories
- Low-profile bracket
- MTBF
- 1,677,495 hours
- FCC, RoHS, WEEE, UASP (USB Attached SCSI Protocol)
- Red
- OS Required
- 6.89 cm
- 10.2 cm
- 1.44 cm
- 60 g
- Shipping Width
- 14.2 cm
- Shipping Depth
- 17 cm
- Shipping Height
- 3 cm
- Shipping Weight
- 125 g
- Limited warranty - 2 years
- 0 °C
- 70 °C
- 15 - 90% (non-condensing)
StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter | In Stock | £5.06 |
StarTech.com 2 Port USB 3.0 A Female Slot Plate Adapter | In Stock | £18.98 |
StarTech.com USB 3.1 USB-C to USB-A Adapter | In Stock | £9.01 |
StarTech.com 1m USB 3.1 USB-C to USB-A Cbl | In Stock | £7.59 |
StarTech.com 1m USB 3.1 C to Micro-B Cable | In Stock | £10.24 |
StarTech.com StarTech.com 2-Port 10Gbps USB-A/USB-C PCIe Card -USB 3.1 | In Stock | £38.05 |
StarTech.com 2-Port USB 3.2 Gen 2 PCIe Card - USB-A SuperSpeed 10Gbps PCI Express 3.0 x2 | In Stock | £24.39 |
StarTech.com 4-Port USB 3.2 Gen 2 PCIe Card - USB-A SuperSpeed 10Gbps PCI Express 3.0 x4 | In Stock | £87.44 |
StarTech.com 1-Port USB 3.2 Gen 2x2 PCIe Card - USB-C SuperSpeed 20Gbps PCI Express 3.0 x4 | In Stock | £40.64 |
StarTech.com 4-Port USB PCIe Card | In Stock | £101.62 |
StarTech.com 5-Port USB PCIe Card, 10Gbps | In Stock | £56.66 |
StarTech.com 4-Port USB-A PCIe Card, 5Gbps | In Stock | £80.54 |
StarTech.com 4-Port USB-C 10Gb PCIe Card | In Stock | £201.91 |
StarTech.com 4-Port USB-C 10Gb PCIe Card | In Stock | £206.78 |
