StarTech.com 5 Port Industrial Gigabit Ethernet Switch
Quicklinx: B12GWS00 Mfr#: IES51000
Type: Gigabit Ethernet
Ports: 5
Data Transfer Rate: 1Gbps
Managed: No
POE: No
£117.14 ex VAT
£140.56 inc VAT
Network up to 5 Ethernet devices through a rugged, industrial Gigabit Ethernet switch - DIN / Wall Mountable. The IES51000 5-Port Industrial Ethernet Switch offers 5 Gigabit Ethernet ports in a compact, IP30-rated metal enclosure, making it the ideal network solution for harsh industrial environments such as factory floors, warehouses or large junction boxes.
Quickly connect your network devices with little to no configuration. This unmanaged industrial network switch supports 10/100/1000 Mbps transfer speeds, full/half-duplex auto-negotiation, jumbo frames and auto MDI/MDIX, which helps to eliminate the hassle of troubleshooting mis-matched speed and duplex settings.
Providing seamless operation in the event of power dips or failures, the switch features redundant 12-58V DC terminal block power inputs to help prevent unnecessary downtime. When used with two power sources, the switch also supports alarm relay contacts that you can wire to your existing alarm circuit to notify you instantly when a power disruption occurs.
For easy installation and dependable performance in harsh environments, the switch can be DIN Rail or wall mounted and features a compact, IP30-rated enclosure with an extended operating temperature range (-40°C to 75°C).
StarTech.com 5 Port Unmanaged Industrial Gigabit Ethernet Switch - DIN Rail / Wall-Mountable Network Switch - Rugged IP30 Gigabit Switch (IES51000) - switch - 5 ports
Switch - 5 ports
Subtype
Gigabit Ethernet
Ports
5 x 10/100/1000
Performance
Forwarding performance (full duplex): 2 Gbps
Jumbo Frame Support
9KB
Flow control, auto-uplink (auto MDI/MDI-X), store and forward, half duplex mode, full duplex mode, wall mountable, Quality of Service (QoS), 128KB packet buffer, Link Aggregation Control Protocol (LACP), Energy Efficient Ethernet
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP)
DC 12 -58 V
8.94 cm x 11.22 cm x 2.91 cm
329 g
Switch - 5 ports
Enclosure Type
Desktop, DIN rail mountable, wall-mountable
Subtype
Gigabit Ethernet
Ports
5 x 10/100/1000
Performance
Jumbo Frame Support
9KB
Status Indicators
Port transmission speed, power, alarm, link/activity
5 x 1000Base-T RJ-45 , 1 x 6 pin terminal block
Internal power supply
DC 12 -58 V
3.63 Watt
Mounting brackets
Rack Mounting Kit
Included
FCC, RoHS
8.94 cm
11.22 cm
2.91 cm
329 g
-40 °C
75 °C
5 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
85 °C
B12G StarTech.com 3 ft Cat5e Blue Molded RJ45 UTP Cat 5e Patch Cable In Stock £2.62
B12G StarTech.com 5 Port Unmanaged Industrial Gigabit PoE Switch with 4 Power over Ethernet ports In Stock £166.00
B12G StarTech.com 6 Port Industrial Gigabit Ethernet Switch, 4 PoE+ Ports and Voltage Regulation In Stock £225.18
B12G StarTech.com 8 Port Unmanaged Industrial Gigabit Power over Ethernet Switch - 802.3af/at PoE+ Switch In Stock £187.91
B12G StarTech.com 5 Port Industrial Gigabit Ethernet Switch In Stock £117.14
Ports: 5
Managed: No
POE: No
Price Range Ex VAT: 100 - 150
