Extend a USB 3.0 port from the back of your computer to your desktop. The USB3SEXT5DKB Black Desktop USB 3.0 Extension Cable connects to an available USB female port on a Mac or PC computer, allowing you to relocate the USB (female) port up to 5-feet away from the computer case. By extending the USB 3.0 port away from the computer case, you can situate a USB 3.0 port from the computer in a more practical spot, such as on top of the computer case or on a desktop.
The extension cable features high quality Shielded Twisted Pair (STP) construction, helping to prevent electro-magnetic interference and ensuring reliable data communication.
                Robust constructionThis USB extension cable features a sturdy design with nickel-plated connectors that resist corrosion and enhance connectivity reliability.
                High-speed data transferWith USB 3.0 compliance, this cable provides fast data transfer rates, ensuring efficient connection for devices requiring high bandwidth.
                Versatile compatibilityDesigned to work seamlessly with various USB devices, this cable is compatible with both USB 2.0 and USB 3.0 standards, providing extended usage across different setups.
- StarTech.com 5ft SuperSpeed USB 3.0 Extension Cable for Desktop - STP - USB-A Male to USB-A Female Cable for Computer - Black (USB3SEXT5DKB) - USB extension cable - USB Type A to USB Type A - 1.5 m
- Technology
- Shielded twisted pair (STP)
- Length
- 1.5 m
- Connector
- 9 pin USB Type A - female
- Connector (Second End)
- 9 pin USB Type A - male
- USB / USB 2.0 / USB 3.0
- Black
- Limited lifetime warranty
- Designed For
- P/N: CFASTRWU3, S355BU33ERM, USB3SAA3MBK
- Technology
- American Wire Gauge (AWG)
- 28
- Plated Connector
- Nickel
- Length
- 1.5 m
- Black
- Connector
- USB / USB 2.0 / USB 3.0, RoHS
- Designed For
|  | StarTech.com 5 ft Desktop SuperSpeed USB 3.0 Extension Cable - A to A M/F | In Stock | £12.04 |
|  | StarTech.com 5 ft Black Desktop SuperSpeed USB 3.0 Extension Cable - A to A M/F | In Stock | £11.77 |
|  | StarTech.com 6in USB 3.0 Extension Cable | In Stock | £5.72 |
|  | StarTech.com 3m 10ft USB 3.0 A to A Cable | In Stock | £7.16 |
