StarTech.com 5 ft Desktop SuperSpeed USB 3.0 Extension Cable - A to A M/F
Quicklinx: 7P44BTBS Mfr#: USB3SEXT5DSK
Length: 1.5m
£12.04 ex VAT
£14.44 inc VAT
Extend a USB 3.0 port from the back of your computer to your desktop. The USB3SEXT5DSK Desktop USB 3.0 Extension Cable connects to an available USB female port on a Mac or PC computer, allowing you to relocate the USB (female) port up to 5-feet away from the computer case. By extending the USB 3.0 port away from the computer case, you can situate a USB 3.0 port from the computer in a more practical spot, such as on top of the computer case or on a desktop.
Designed for next-generation SuperSpeed USB device connections, this USB 3.0 A-to-A Male/Female cable provides connectivity between a PC and hub or other USB devices, supporting a throughput of up to 5Gbps when used with a USB 3.0 host and device - an astounding 10x the capability of USB 2.0 (480Mbps).
The 5ft USB 3.0 A to A desktop cable features high quality Shielded Twisted Pair (STP) construction, helping to prevent electro-magnetic interference and ensuring reliable data communication.
StarTech.com 5 ft Desktop SuperSpeed USB 3.0 Extension Cable - A to A M/F - USB extension cable - USB Type A (M) to USB Type A (F) - 5 ft - black - USB3SEXT5DSK - USB extension cable - USB Type A to USB Type A - 1.5 m
USB extension cable
Shielded
Length
1.5 m
Connector
9 pin USB Type A - male
Connector (Second End)
9 pin USB Type A - female
P/N: 2SD4FCRU3, CFASTRWU3, FCREADMICRO3, MSDREADU3CA, USB3SAA3MBK
USB extension cable
Shielded
American Wire Gauge (AWG)
28
Length
1.5 m
Connector
RoHS
7P44 StarTech.com 5ft Desktop USB Extension Cable - A Male to A Female In Stock £5.24
7P44 StarTech.com 5 ft Desktop SuperSpeed USB 3.0 Extension Cable - A to A M/F In Stock £12.04
7P44 StarTech.com 1m Blue SuperSpeed USB 3.0 Extension Cable A to A - M/F In Stock £6.58
7P44 StarTech.com 1m Black SuperSpeed USB 3.0 Extension Cable A to A - M/F In Stock £6.73
7P44 StarTech.com 5 ft Black Desktop SuperSpeed USB 3.0 Extension Cable - A to A M/F In Stock £11.77
7P44 StarTech.com 2m Black SuperSpeed USB 3.0 Extension Cable A to A - M/F In Stock £7.23
7P44 StarTech.com 6in USB 3.0 Extension Cable In Stock £5.45
7P44 StarTech.com 3m 10ft USB 3.0 A to A Cable In Stock £7.16
Length: 1.5m
