Extend a USB 3.0 port from the back of your computer to your desktop. The USB3SEXT5DKB Black Desktop USB 3.0 Extension Cable connects to an available USB female port on a Mac or PC computer, allowing you to relocate the USB (female) port up to 5-feet away from the computer case. By extending the USB 3.0 port away from the computer case, you can situate a USB 3.0 port from the computer in a more practical spot, such as on top of the computer case or on a desktop.
The extension cable features high quality Shielded Twisted Pair (STP) construction, helping to prevent electro-magnetic interference and ensuring reliable data communication.
Robust construction
This USB extension cable features a sturdy design with nickel-plated connectors that resist corrosion and enhance connectivity reliability. -
High-speed data transfer
With USB 3.0 compliance, this cable provides fast data transfer rates, ensuring efficient connection for devices requiring high bandwidth. -
Versatile compatibility
Designed to work seamlessly with various USB devices, this cable is compatible with both USB 2.0 and USB 3.0 standards, providing extended usage across different setups.
- StarTech.com 5ft SuperSpeed USB 3.0 Extension Cable for Desktop - STP - USB-A Male to USB-A Female Cable for Computer - Black (USB3SEXT5DKB) - USB extension cable - USB Type A to USB Type A - 1.5 m
- Technology
- Shielded twisted pair (STP)
- Length
- 1.5 m
- Connector
- 9 pin USB Type A - female
- Connector (Second End)
- 9 pin USB Type A - male
- USB / USB 2.0 / USB 3.0
- Black
- Limited lifetime warranty
- Designed For
- P/N: CFASTRWU3, S355BU33ERM, USB3SAA3MBK
- Technology
- American Wire Gauge (AWG)
- 28
- Plated Connector
- Nickel
- Length
- 1.5 m
- Black
- Connector
- USB / USB 2.0 / USB 3.0, RoHS
- Designed For
StarTech.com 5 ft Desktop SuperSpeed USB 3.0 Extension Cable - A to A M/F | In Stock | £11.51 |
StarTech.com 5 ft Black Desktop SuperSpeed USB 3.0 Extension Cable - A to A M/F | In Stock | £11.51 |
StarTech.com 6in USB 3.0 Extension Cable | In Stock | £5.45 |
StarTech.com 3m 10ft USB 3.0 A to A Cable | In Stock | £7.00 |
