Add 5.1 channel audio to a desktop PC through a low profile PCI slot. This 5 channel PCI sound adapter card is the ideal sound solution for low profile/small form factor PC computers, supporting full-duplex operation with 6 outbound streams and 2 simultaneous input streams.
Offering everything you need to take your multimedia experience to the next level, the 5-channel sound card supports the latest Dolby Digital EX and DTS 5.1 channel DVD soundtracks, and 96Khz/24bit audio playback.
The sound card includes Windows WDM supported drivers, which save both time and hassle, allowing you to add high quality audio in minutes.
Equipped with a low profile bracket, the 5-channel sound card also includes a standard profile (full-height) mounting bracket and is PCI v2.2 compliant, so it can be installed in virtually any PCI-capable PC regardless of the size of the computer case - a cost-effective HTPC (Home Theater PC) solution!
- StarTech.com 5 Channel Low Profile PCI Sound Adapter Card – 24 Bits - sound card
- Sound card - low profile
- Enclosure Type
- Internal
- Interface Type
- PCI
- 1.8 cm x 12.1 cm x 8 cm
- 60 g
- Signal Processor
- VIA VT1723
- Sound Output Mode
- 5.1 channel surround
- DAC Resolution
- 24-bit
- Sample Rate
- 96 kHz (max)
- System Requirements
- Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows Server 2003 x64 Edition, Microsoft Windows 2003, Microsoft Windows Vista (32/64 bits)
- 2-year warranty
- Form Factor
- Internal
- Interface Type
- PCI
- 1.8 cm
- 12.1 cm
- 8 cm
- 60 g
Processor / Memory
- Signal Processor
- VIA VT1723
Audio Output
- Sound Output Mode
- DAC Resolution
- 24-bit
- Sample Rate
- 96 kHz (max)
- Dolby Digital 5.1, Dolby Digital EX, WDM
- Audio Modes
- Playback: 24-bit 96 kHz , Record: 16-bit 48 kHz
- 1 x speakers (rear) - mini-phone stereo 3.5 mm , 1 x speakers (center/subwoofer) - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x microphone - mini-phone 3.5 mm
- FCC, RoHS
- OS Required
- Limited warranty - 2 years
- 20 °C
- 50 °C
- 20 - 80%
