StarTech.com 5.25 to 3.5 Drive Hot Swap Bay
Quicklinx: D387WS00 Mfr#: HSB13SATSASB
Hot-swap drives with ease, using this trayless mobile backplane for desktop PCs or servers. This removable hard drive hot-swap bay makes it easy to swap 3.5" SATA or SAS drives in and out of your server or desktop computer, using an available 5.25" front drive bay. It features a trayless design that saves you installation time and enables you to insert or remove drives as needed. With its durable plastic and aluminum construction, it provides a cost-effective solution for drive maintenance and interchangeability of data between multiple systems.
This hot-swap bay/mobile rack is ideal for IT professionals, such as system administrators or computer operators, for quickly swapping drives.
With support for both SATA and SAS 3.5" drives, it saves valuable time in environments where storage drives need to be replaced or removed regularly, such as in server rooms and data centers. Its cost-effective design makes it ideal for large deployments of system builds or upgrades, and for organizations intent on maximizing their IT budget spend.
The removable hard drive hot-swap bay provides a protective backplane with a lightweight yet durable plastic and aluminum housing. To safeguard your data, you can lock the drive bay door to prevent you from unintentionally disconnecting the drive.
To maximize the speed and performance of your drives, the mobile rack supports SAS I and II and SATA I, II and III, providing data transfer speeds up to 6Gbps when paired with a compatible controller.
StarTech.com 5.25 to 3.5 Hard Drive Hot Swap Bay - Trayless - Lockable - Front Mount - Hard Drive Bay - Hard Drive Backplane - HDD Caddy (HSB13SATSASB) - storage bay adapter - SATA 6Gb/s / SAS 6Gb/s
Storage bay adapter
Supported Form Factor
5.25" to 3.5"
Expansion Bays
1 x hot-swap - 3.5"
Compatible Bay
1 5.25"
Supported Interface
SATA-600 / SAS
Product Material
Plastic, aluminium
P/N: 25SATSAS35HD
Storage bay adapter
5.25" to 3.5"
Product Material
Plastic, aluminium
Supported Interface
SATA-600 / SAS
Storage Controller
No CPU
Bays
1 x hot-swap - 3.5"
Compatible Bay
1 x drive cage 5.25"
2 security keys
1 x Serial ATA / SAS cable
Mounting Kit
Included
P/N: 25SATSAS35HD
D387 StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter In Stock £5.06
D387 StarTech.com 12in LP4 to 2x SATA Power Y Cable Adapter In Stock £4.48
D387 StarTech.com 12in Latching SATA Cable In Stock £6.16
D387 StarTech.com 18in Latching SATA Cable In Stock £4.24
D387 StarTech.com 24in Latching SATA Cable In Stock £6.84
D387 StarTech.com 8in Latching SATA to SATA Cable - F/F In Stock £5.44
D387 StarTech.com 12in LP4 to 2x Latching SATA Power Y Cable Splitter Adapter - 4 Pin Molex to Dual SATA In Stock £5.50
D387 StarTech.com 6in Latching SATA Power Y Splitter Cable Adapter - M/F In Stock £5.60
D387 StarTech.com 5.25 to 3.5 Drive Hot Swap Bay In Stock £29.81
D387 StarTech.com 2.5 to 3.5 Hard Drive Adapter In Stock £23.17
D387 StarTech.com 18in Right Angle SATA Cable In Stock £4.34
