Turn almost any 2.5" SATA/SAS drive into a 3.5" drive. This 2.5" to 3.5" hard drive adapter lets you install a 2.5" SATA or SAS hard drive (HDD) or solid-state drive (SSD) into an internal or external 3.5" drive bay, using standard drive-mounting holes.
The 2.5" to 3.5" hard drive bay adapter lets you install a newer, higher performance drive such as an SSD into a legacy system that may only support a 3.5" hard drive. It provides a cost-efficient way to enhance storage performance and reliability without expensive upgrades to core IT systems. It's also ideal for system administrators who want to build a system that takes advantage of the increased performance of a 2.5" HDD/SSD.
To utilize the full speed potential of your SATA/SAS drive, the adapter supports transfer speeds up to 6Gbps.
You can install the adapter into a desktop, server, storage-array, hot-swap bay, and drive drawer. It offers permanent installation in a 3.5" drive bay with standard mounting holes. When the adapter is installed, you simply slide a 2.5" HDD/SSD into the adapter enclosure, with no tools required.
The adapter is suitable for drives with a height of up to 15 mm. Virtually any 2.5" SATA/SAS drive can be made to look and function like a 3.5" drive.
The adapter includes a label you can use to track and record information about the installed drive.
Versatile compatibility
Designed to accommodate both 2.5-inch and 3.5-inch drives, the StarTech.com adapter offers flexibility for different storage types, making it a valuable addition to any setup. -
High-speed data transfer
With data transfer rates reaching up to 6 Gbit/s, this adapter ensures quick access to data, enhancing overall system performance and efficiency. -
Hot-swappable design
This feature allows for easy insertion and removal of drives without needing to power down the system, facilitating seamless upgrades and maintenance. -
Robust construction
Made from both plastic and aluminum, the enclosure is designed for durability, providing reliable protection for your valuable data storage. -
Compliant with industry standards
Meets FCC, RoHS, and WEEE standards, ensuring the product aligns with environmental and safety regulations, thus fostering responsible usage.
- StarTech.com 2.5 to 3.5 Hard Drive Adapter - For SATA and SAS SSDs/HDDs - SSD Enclosure - HDD Enclosure - Internal Hard Drive Enclosure (25SATSAS35HD) - storage enclosure - SATA 6Gb/s / SAS 6Gb/s - SAS 6Gb/s, SATA 6Gb/s
- Storage enclosure - internal
- Bus Type
- Black, silver
- Expansion Bays
- 1 x internal - 2.5" x 1/8H
- Compatible Bay
- 1 3.5" x 1/3H
- Hard Drive Form Factor Compatibility
- 2.5"
- Supported Interface
- SATA-600 / SAS 2.0
- Drive Connector
- 29 pin internal SAS (SFF-8482)
- Bay Connector
- 22 pin Serial ATA
- Interface
- Data Transfer Rate
- 6 Gbit/s
- Supported Devices
- Hard drive, solid state drive
- Product Material
- Plastic, aluminium
- 10.1 cm x 14.6 cm x 2.6 cm
- 252 g
- 2-year warranty
- 2.5"
- Hard Drive Maximum Height
- 15 mm
- Host Bus
- Product Material
- Black, silver
Storage Controller
- Interface
- 6 Gbit/s
- Supported Devices
- Bays
- 1 x SATA 6Gb/s
- Connections
- 1 - 22 pin Serial ATA
- Compatible Bay
- 1 x internal 3.5" x 1/3H
- Hot-swappable, S.M.A.R.T. support, TRIM support, 4Kn drive compatible
- Mounting Kit
- Included
- FCC, RoHS, WEEE
- Limited warranty - 2 years
- 10.1 cm
- 14.6 cm
- 2.6 cm
- 252 g
- Shipping Weight
- 252 g
- 0 °C
- 55 °C
- 5 - 65%
StarTech.com 3.5in Hard Drive to 5.25in Front Bay Bracket Adapter | In Stock | £5.88 |
StarTech.com 5.25in Trayless Hot Swap Mobile Rack for 3.5in Hard Drive | In Stock | £20.68 |
StarTech.com 6in SATA Serial ATA Cable | In Stock | £3.61 |
StarTech.com 12in SATA Serial ATA Cable | In Stock | £5.00 |
StarTech.com 6in Latching SATA Cable | In Stock | £2.60 |
StarTech.com 5.25 to 3.5 Drive Hot Swap Bay | In Stock | £31.20 |
