Hot-swap drives with ease, using this trayless mobile backplane for desktop PCs or servers. This removable hard drive hot-swap bay makes it easy to swap 3.5" SATA or SAS drives in and out of your server or desktop computer, using an available 5.25" front drive bay. It features a trayless design that saves you installation time and enables you to insert or remove drives as needed, creating a convenient solution for drive maintenance and interchangeability of data between multiple systems.
This hot-swap bay/mobile rack is ideal for IT professionals, such as system administrators or computer operators, for quickly swapping, replacing, or transporting drives between various systems and locations. With support for both SATA and SAS 3.5" drives, it saves valuable time in environments where storage drives need to be replaced or removed regularly, such as in server rooms and data centers.
The hot-swap bay provides a protective backplane with a durable aluminum housing that offers ventilation to ensure proper air flow and heat dissipation. To safeguard your data, you can lock the drive bay door to prevent unauthorized access to your drive.
To maximize the speed and performance of your drives, the mobile rack supports SAS I and II and SATA I, II and III, providing data transfer speeds up to 6Gbps when paired with a compatible controller.
- StarTech.com 5.25" to 3.5" Trayless Hard Drive Hot Swap Bay - Removable Hard Drive Bay for 3.5" SATA/SAS Drives - Aluminum (HSB1SATSASBA) - storage bay adapter
- Storage bay adapter
- Supported Form Factor
- 5.25" to 3.5"
- Expansion Bays
- 1 x hot-swap - 3.5"
- Compatible Bay
- 1 5.25"
- Designed For
- P/N: 25SATSAS35HD
- 5.25" to 3.5"
Storage Controller
- Processor
- No CPU
- Bays
- Compatible Bay
- 1 x drive cage 5.25"
- Designed For
- P/N: 25SATSAS35HD
StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter | In Stock | £4.44 |
StarTech.com 12in LP4 to 2x SATA Power Y Cable Adapter | In Stock | £4.12 |
StarTech.com 12in Latching SATA Cable | In Stock | £5.40 |
StarTech.com 18in Latching SATA Cable | In Stock | £4.48 |
StarTech.com 24in Latching SATA Cable | In Stock | £5.98 |
StarTech.com 5.25in Trayless Hot Swap Mobile Rack for 3.5in Hard Drive | In Stock | £17.78 |
StarTech.com 2 Drive 2.5in Trayless Hot Swap SATA Mobile Rack Backplane | In Stock | £43.92 |
StarTech.com 6in 4 Pin Molex to Right Angle SATA Power Cable Adapter | In Stock | £5.01 |
StarTech.com 8in Latching SATA to SATA Cable - F/F | In Stock | £5.34 |
StarTech.com 12in LP4 to 2x Latching SATA Power Y Cable Splitter Adapter - 4 Pin Molex to Dual SATA | In Stock | £5.12 |
StarTech.com 12in LP4 to 2x Right Angle Latching SATA Power Y Cable Splitter - 4 Pin Molex to SATA | In Stock | £4.30 |
StarTech.com 6in Latching SATA Power Y Splitter Cable Adapter - M/F | In Stock | £5.40 |
StarTech.com 5.25 to 3.5 Drive Hot Swap Bay | In Stock | £33.35 |
StarTech.com 2.5 to 3.5 Hard Drive Adapter | In Stock | £26.01 |
StarTech.com 18in Right Angle SATA Cable | In Stock | £4.24 |
