StarTech.com 5.25 to 3.5 Drive Hot Swap Bay
Quicklinx: CZYYWS00 Mfr#: HSB1SATSASBA
Type: Storage bay adapter
HD Size: 3.5 / 5.25 shared
Power Supply: [N/A]
£30.05 ex VAT
£36.06 inc VAT
Hot-swap drives with ease, using this trayless mobile backplane for desktop PCs or servers. This removable hard drive hot-swap bay makes it easy to swap 3.5" SATA or SAS drives in and out of your server or desktop computer, using an available 5.25" front drive bay. It features a trayless design that saves you installation time and enables you to insert or remove drives as needed, creating a convenient solution for drive maintenance and interchangeability of data between multiple systems.
This hot-swap bay/mobile rack is ideal for IT professionals, such as system administrators or computer operators, for quickly swapping, replacing, or transporting drives between various systems and locations. With support for both SATA and SAS 3.5" drives, it saves valuable time in environments where storage drives need to be replaced or removed regularly, such as in server rooms and data centers.
The hot-swap bay provides a protective backplane with a durable aluminum housing that offers ventilation to ensure proper air flow and heat dissipation. To safeguard your data, you can lock the drive bay door to prevent unauthorized access to your drive.
To maximize the speed and performance of your drives, the mobile rack supports SAS I and II and SATA I, II and III, providing data transfer speeds up to 6Gbps when paired with a compatible controller.
  • Efficient Design
    Supports a 5.25" to 3.5" form factor adaptation, enabling the use of 3.5" SATA/SAS drives in a standard 5.25" bay.
  • Hot-Swap Capability
    Allows for quick and easy drive replacement without needing to power down the system, enhancing workflow efficiency.
StarTech.com 5.25" to 3.5" Trayless Hard Drive Hot Swap Bay - Removable Hard Drive Bay for 3.5" SATA/SAS Drives - Aluminum (HSB1SATSASBA) - storage bay adapter
Storage bay adapter
Supported Form Factor
5.25" to 3.5"
Expansion Bays
1 x hot-swap - 3.5"
Compatible Bay
1 5.25"
P/N: 25SATSAS35HD
Storage bay adapter
5.25" to 3.5"
Storage Controller
No CPU
Bays
1 x hot-swap - 3.5"
Compatible Bay
1 x drive cage 5.25"
P/N: 25SATSAS35HD
CZYY StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter In Stock £4.60
CZYY StarTech.com 12in LP4 to 2x SATA Power Y Cable Adapter In Stock £4.26
CZYY StarTech.com 12in Latching SATA Cable In Stock £5.50
CZYY StarTech.com 18in Latching SATA Cable In Stock £4.40
CZYY StarTech.com 24in Latching SATA Cable In Stock £6.08
CZYY StarTech.com 5.25in Trayless Hot Swap Mobile Rack for 3.5in Hard Drive In Stock £17.69
CZYY StarTech.com 2 Drive 2.5in Trayless Hot Swap SATA Mobile Rack Backplane In Stock £43.75
CZYY StarTech.com 6in 4 Pin Molex to Right Angle SATA Power Cable Adapter In Stock £5.00
CZYY StarTech.com 8in Latching SATA to SATA Cable - F/F In Stock £5.30
CZYY StarTech.com 12in LP4 to 2x Latching SATA Power Y Cable Splitter Adapter - 4 Pin Molex to Dual SATA In Stock £4.22
CZYY StarTech.com 6in Latching SATA Power Y Splitter Cable Adapter - M/F In Stock £5.32
CZYY StarTech.com 5.25 to 3.5 Drive Hot Swap Bay In Stock £30.05
CZYY StarTech.com 2.5 to 3.5 Hard Drive Adapter In Stock £23.64
CZYY StarTech.com 18in Right Angle SATA Cable In Stock £4.36
Power Supply: [N/A]
