StarTech.com 5.25" USM Storage Bay with 2.5" SATA USM / USB 3.0 Hard Drive Enclosure
Quicklinx: 95FNWS00 Mfr#: S2510U33RUSM
  • Windows 8 (32/64 bits)
Add a hot swap 5.25" USM bay to a PC, and connect your 2.5" SSD/HDD with the included enclosure.
The S2510U33RUSM USM Removable Storage Bay and Enclosure turns a 5.25" front computer bay into a hot-swappable USM interface for you to connect a 2.5" SATA hard drive (HDD) or solid state drive (SSD), using the included USM enclosure. Both the bay and enclosure are compatible with Seagate GoFlex and other USM interface devices, and support SATA III transfer speeds up to 6.0 Gbps.
USM (Universal Storage Module) is a portable drive standard that interfaces with SATA and enables you to hot-swap drives between multiple host devices, such as PCs, notebooks, DVRs and many others.
Using the included USM to USB 3.0 adapter, the enclosure can also be connected externally to non-USM host devices via USB. Plus, with support for UASP, the enclosure performs up to 70% faster than conventional USB when paired with a UASP-enabled host controller, to utilize the full potential of your SATA III hard drives.
For even more versatility, StarTech.com offers the SAT2510U33USM, an additional 2.5in USM SATA Hard Drive Enclosure, which offers the option to swap multiple drives in and out of the main computer as needed.
The USM removable hard drive bay interfaces with SATA, and can be mounted into any 5.25" front bay, to provide a hot-swappable mobile rack. The bay features push-button ejection allowing drives to easily be installed and removed from the computer system, providing a convenient method of creating backups that can then be removed for safe keeping, archiving or external portable access.
UASP is supported in Windows 8, Mac (OSX 10.8 or above), and Linux. In testing UASP performs with a 70% faster read speed and 40% faster write speed over traditional USB 3.0 at peak performance.
At the same peak in testing UASP also shows an 80% reduction in required processor resources.
StarTech.com 5.25" USM Storage Bay with 2.5" SATA USM USB 3.0 HDD Enclosure - storage bay adapter
Storage bay adapter
Supported Form Factor
5.25" to 2.5"
Expansion Bays
1 x front accessible - 2.5"
Compatible Bay
1 5.25"
Product Material
Plastic, aluminium
Linux, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits)
14.83 cm x 15.28 cm x 4.19 cm
169.7 g
Storage bay adapter
5.25" to 2.5"
Product Material
Plastic, aluminium
Storage Controller
No CPU
Bays
1 x SATA 6Gb/s - SATA combo
Compatible Bay
1 x external 5.25"
2.5" USM HDD enclosure, USM to USB 3.0 interface adapter
1 x micro-USB cable - external
LED indicator
Mounting Kit
Included
Plug and Play, FCC, RoHS
14.83 cm
15.28 cm
4.19 cm
169.7 g
10 - 90%
95FN StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter In Stock £5.06
95FN StarTech.com 18in Latching SATA Cable In Stock £4.24
95FN StarTech.com 6in SATA Power Y Splitter Cable Adapter - M/F In Stock £6.34
95FN StarTech.com 4x SATA Power Splitter Adapter Cable In Stock £6.60
95FN StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to Micro B Cable - M/M In Stock £9.41
