StarTech.com 4x M.2 to SATA 3.5in adapter
Quicklinx: B7YNWS00 Mfr#: 35S24M2NGFF
Type: Storage controller
HD Size: M.2
£34.68 ex VAT
£41.61 inc VAT
Enhance your system by mounting four M.2 (NGFF) SATA-based SSDs into one 3.5" drive bay. Here's an easy way to increase the speed, capacity and data security of your desktop computer or server. This four-drive M.2 SATA adapter and mounting bracket lets you add up to four M.2 solid-state drives in the same space as a single 3.5" SATA drive.
The M.2 adapter increases overall storage potential by installing four M.2 NGFF (Next Generation Form Factor) SSDs in a standard 3.5" drive bay. Utilize the full potential of your SATA III controller with an M.2 SSD, reducing data transfer bottlenecks and giving you file transfer rates of up to 6Gbps.
Create a high-performance RAID solution using four M.2 SSDs with your RAID controller to increase the volume capacity of your drive array and add redundancy to protect your data against drive failure. You can combine all four drives together to appear as one, to store larger files such as digital media and access them at faster speeds.
The adapter ensures easy and versatile use. It is designed to support a wide range of M.2 NGFF SSDs, including 2230, 2242, 2260, 2280 and 22110 drive sizes. It's also compatible with Windows, Mac, and Linux systems without having to install additional drivers or software.
StarTech.com 4-Drive M.2 SSD (NGFF) to SATA Hard Drive Adapter for 3.5" Drive Bay - Supports 2230/2242/2260/2280/22110 M.2 NGFF SATA - 6Gbps (35S24M2NGFF) - storage controller - SATA 6Gb/s - SATA 6Gb/s
Storage controller - internal
Bus Type
SATA 6Gb/s
Hard Drive Form Factor Compatibility
M.2
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Solid state drive
Max Storage Devices Qty
4
10 cm x 13.9 cm x 3.4 cm
226 g
M.2
Host Bus
SATA 6Gb/s
Storage Controller
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Solid state drive
4
No CPU
4 x M.2 Card - M.2 Card
4 x SATA 6Gb/s - 22 pin Serial ATA
4 x Serial ATA cable - external , 1 x power extension cable - external
Mounting Kit
Included
MTBF
1,920,042 hours
FCC, RoHS
10 cm
13.9 cm
3.4 cm
226 g
5 °C
50 °C
20 - 80%
B7YN StarTech.com 18" Serial ATA Cable w/R Angle In Stock £5.00
B7YN StarTech.com 18in SATA Serial ATA Cable In Stock £2.45
B7YN StarTech.com 12in Latching SATA Cable In Stock £6.16
B7YN StarTech.com 18in Latching SATA Cable In Stock £4.24
B7YN StarTech.com 24in Latching SATA Cable In Stock £6.84
B7YN StarTech.com 12in Latching SATA to Right Angle SATA Serial ATA Cable In Stock £4.98
B7YN StarTech.com 18in SATA to Left Angle SATA Serial ATA Cable - F/F In Stock £6.16
B7YN StarTech.com 6in Latching SATA Cable In Stock £2.60
B7YN StarTech.com 8in Latching SATA to SATA Cable - F/F In Stock £3.51
B7YN StarTech.com 12in LP4 to 2x Latching SATA Power Y Cable Splitter Adapter - 4 Pin Molex to Dual SATA In Stock £5.50
B7YN StarTech.com 6in Latching SATA Power Y Splitter Cable Adapter - M/F In Stock £5.60
B7YN StarTech.com mSATA to SATA HDD / SSD Adapter – Mini SATA to SATA Converter Card In Stock £12.79
B7YN StarTech.com M.2 NGFF SSD to 2.5in SATA Adapter Converter In Stock £15.57
B7YN StarTech.com mSATA SSD to 2.5in SATA Adapter Converter In Stock £18.13
B7YN StarTech.com Dual mSATA SSD to 2.5" SATA RAID Adapter Converter In Stock £14.65
B7YN StarTech.com M.2 SATA external SSD enclosure USB 3.0 with UASP In Stock £19.88
B7YN StarTech.com 2x M.2 SSD Controller - PCIe In Stock £21.26
B7YN StarTech.com M.2 SATA Enclosure with USB-C In Stock £25.86
B7YN StarTech.com x4 PCI Express to M.2 PCIe SSD Adapter In Stock £18.76
B7YN StarTech.com 3PT M.2 SSD Card - PCIe 3.0 In Stock £28.55
B7YN StarTech.com U.2 to PCIe Adapter -SFF-8639 In Stock £27.51
B7YN StarTech.com x8 Dual M.2 PCI Express SSD Adapter - PCIe 3.0 for PCIe NVMe In Stock £135.47
B7YN StarTech.com M.2 SSD Enclosure for M.2 SATA Drives - USB 3.1 - USB C M.2 In Stock £29.33
HD Size: M.2
