This Thunderbolt 3 to 4x M.2 PCIe SSD enclosure enables you to turn four M-Key PCI-Express based M.2 NVMe or AHCI solid state drives (SSDs) into a high-performance external storage solution. The SSD enclosure is self-powered with an included 72W EPS power supply that powers the enclosure, the connected drives, and provides up to 15W of power to any downstream Thunderbolt 3 devices. A 2.3 ft. (70 cm) Thunderbolt 3 Certified host cable is also included, to connect the enclosure to your computer.
High Performance M.2 Storage via 40Gbps Thunderbolt 3
The enclosure is compatible with 80mm M.2 PCIe based (M-Key) single/double-sided SSDs. Create an external storage solution that utilizes the high-performance bandwidth available to your Thunderbolt 3 port, providing combined data transfer speeds of up to 40Gbps for up to four drives. The vented metal enclosure features thermal pads and a cooling fan to ensure your SSDs are operating at optimal temperatures. -
Dedicated 8Gbps Throughput for Each Individual Drive
A single 8 Gbps PCIe lane is dedicated to each connected drive. This ensures consistent read/write performance across the entire enclosure, regardless of individual drive activity. The enclosure also supports software RAID with storage management systems like Storage Spaces (Microsoft), RAID Assistant (macOS), or mdraid/mdadm (Linux). The support for software RAID, combined with exceptional drive performance, makes this the ideal enclosure for creative professionals working with large files such as high-resolution graphics, video, and CAD files. -
Thunderbolt Certified
This enclosure is Thunderbolt Certified to ensure an optimal user experience and compatibility when connected to a Thunderbolt 3 host device, such as a MacBook Pro 16, 13, Air, Lenovo ThinkPad X1 Carbon / T Series, Dell XPS / Latitude / Precision or HP EliteBook. The external drive enclosure is also forward compatible with Thunderbolt 4 devices (at Thunderbolt 3 performance). -
Additional Ports for Workspace Flexibility
The enclosure features a DisplayPort output port, enabling you to connect a DisplayPort monitor to your computer through the Thunderbolt 3 enclosure, with resolutions up to 4K 60Hz. The enclosure also features a downstream Thunderbolt 3 port for daisy chaining an additional TB3 device or connect an additional TB3 compatible display (up to 5K 60Hz). M2E4BTB3 is backed by a 2-year StarTech.com warranty, with free lifetime North American based multilingual technical support. Notes: • This device is not compatible with SATA based (B-Keyed or M+B Keyed) M.2 solid state drives. • This device does not support Thunderbolt 2 or Thunderbolt 1 host devices using interface adapters. • This device only supports 80mm M.2 SSDs. • Connected downstream devices share bandwidth with connected SSDs and may reduce overall data transfer performance when connected. • Apple Mac computers with M1 processors can only support one external display connected through the SSD enclosure. However, Apple Mac computers with Intel or M1 Max / Pro processors can support dual external displays connected through the SSD enclosure.
- StarTech.com 4 Bay Thunderbolt 3 NVMe Enclosure, For M.2 NVMe Solid State Drives, 1x DisplayPort Video & 2x TB3 Downstream Ports, Up to 40Gbps, 72W Power Supply - 4 Bay M.2 SSD External Hard Drive Enclosure (M2E4BTB3) - storage enclosure - M.2 NVMe Card / PCIe (NVMe) - Thunderbolt 3
- Storage enclosure - external
- Bus Type
- Thunderbolt 3
- Black
- Localisation
- Australia, Japan, New Zealand, North Africa, United Kingdom, Europe
- Expansion Bays
- 4 x internal - M.2 NGFF 2280
- Hard Drive Form Factor Compatibility
- M.2
- Interface
- Data Transfer Rate
- 40 GBps
- Supported Devices
- Solid state drive
- Max Storage Devices Qty
- 4
- Power Source
- USB bus
- Power
- AC 110-120 V
- 16 cm x 12 cm x 2 cm
- 610 g
- M.2
- Host Bus
- Thunderbolt 3
- Black
- Localisation
Storage Controller
- Interface
- 40 GBps
- Supported Devices
- Solid state drive
- 4
- Bays
- 1 x DisplayPort - DisplayPort (external) , 4 x PCIe 3.0 x1 (NVMe) - M.2 M key (internal)
- Connections
- 1 x Thunderbolt 3 - 24 pin USB-C
- Cables Included
- 1 x Thunderbolt 3 cable - external - 70 cm
- LED indicator, supports AHCI mode, S.M.A.R.T. support, TRIM support, 4Kn drive compatible
- MTBF
- 50,000 hours
- Power Source
- USB bus
- Power adapter
- Voltage Required
- AC 110-120 V
- 16 cm
- 12 cm
- 2 cm
- 610 g
- Shipping Width
- 23.4 cm
- Shipping Depth
- 15.7 cm
- Shipping Height
- 13.2 cm
- Shipping Weight
- 620 g
- 5 °C
- 45 °C
- 20 - 80%
StarTech.com 0.5m Thunderbolt 3 Cable | In Stock | £28.70 |
StarTech.com 2m Thunderbolt 3 Cable White | In Stock | £39.00 |
StarTech.com 0.8m / 2.7ft Thunderbolt 3 to Thunderbolt 3 Cable - 40Gbps | In Stock | £31.40 |
StarTech.com 3ft DisplayPort 1.4 8K 60Hz | In Stock | £15.92 |
