Install four 2.5" solid-state drives or hard drives into two 5.25" front bays, to add storage to a desktop computer or server. Increase the performance and data storage capacity of your desktop computer or enhance your server room storage, with this 4-drive mounting bracket kit for 2.5" solid-state drives or hard drives.
This drive-mounting bracket lets you add four 2.5" SSDs or HDDs into two 5.25" front bays of your computer or server, allowing you to enhance your data storage capacity. The mounting brackets supports a wide range of 2.5" SSDs/HDDs from 5 to 15 mm in height.
A large built-in fan keeps air moving to dissipate heat build-up, and ensure optimum operating temperatures. Protecting against excessive heat build-up maximizes the life of your drives. The fan also features a dust filter making the mounting bracket ideal for industrial or corporate environments.
Engineered with steel framing, the mounting bracket is designed for dependable performance and durability.
- StarTech.com 4x 2.5in SSD/HDD Mounting Bracket with Cooling Fan - Four-Drive Mounting Bracket for Desktop Computer or Server (BRACKET425F) - storage bay adapter
- Storage bay adapter
- Supported Form Factor
- 5.25" to 2.5"
- Expansion Bays
- 4 x internal - 2.5"
- Compatible Bay
- 2 5.25"
- 2-year warranty
- Designed For
- P/N: M2E4SFF8643, PEX4SFF8643
- 5.25" to 2.5"
Storage Controller
- Processor
- No CPU
- Bays
- Connections
- 1 - 4 PIN internal power
- Compatible Bay
- 2 x internal 5.25"
- Built-in cooling fan
- Limited warranty - 2 years
- Designed For
StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter | In Stock | £5.06 |
StarTech.com 3.5in Universal Hard Drive Mounting Bracket Adapter for 5.25in Bay | In Stock | £3.02 |
StarTech.com 12in LP4 to 2x SATA Power Y Cable Adapter | In Stock | £4.48 |
StarTech.com 12in Latching SATA Cable | In Stock | £6.16 |
StarTech.com 18in Latching SATA Cable | In Stock | £4.24 |
StarTech.com 24in Latching SATA Cable | In Stock | £6.84 |
StarTech.com 3.5in Hard Drive to 5.25in Front Bay Bracket Adapter | In Stock | £5.88 |
StarTech.com 6in SATA Power Y Splitter Cable Adapter - M/F | In Stock | £6.34 |
StarTech.com 6in Latching SATA Cable | In Stock | £2.60 |
StarTech.com 2.5in SATA to Mini SATA SSD Adapter Enclosure | In Stock | £29.96 |
StarTech.com 4x SATA Power Splitter Adapter Cable | In Stock | £6.60 |
StarTech.com Dual 2.5" to 3.5" HDD Bracket for SATA Hard Drives - 2 Drive 2.5" to 3.5" Bracket | In Stock | £7.24 |
StarTech.com 2.5" to 3.5" SATA Aluminium Hard Drive Adapter Enclosure SSD / HDD Height up to 12.5mm | In Stock | £20.49 |
StarTech.com M.2 NGFF SSD to 2.5in SATA Adapter Converter | In Stock | £15.57 |
StarTech.com mSATA SSD to 2.5in SATA Adapter Converter | In Stock | £18.13 |
StarTech.com Dual mSATA SSD to 2.5" SATA RAID Adapter Converter | In Stock | £14.65 |
StarTech.com Tool-Less 2B Mounting Bracket | In Stock | £6.49 |
StarTech.com 6" SATA Power Y Splitter Cable | In Stock | £6.34 |
StarTech.com 2.5 to 3.5 Hard Drive Adapter | In Stock | £23.17 |
