StarTech.com 3.5in Hard Drive to 5.25in Front Bay Bracket Adapter
Quicklinx: 4LV7WS00 Mfr#: BRACKETFDBK
Type: Bracket
Hurry, only 3 left in stock!
£5.88 ex VAT
£7.05 inc VAT
This plastic, floppy-drive adapter bracket lets you install a 3.5in floppy drive into a 5.25in bay. A simple solution that lets you position a 3.5in floppy drive in a computer case as needed (without being confined to the 3.5in floppy bay determined by the case layout), the floppy drive adapter bracket features an attractive open-faced black bezel that provides a snug, secured fit for installed drives.
  • A Versatile Desktop Solution
    The 3.5 to 5.25 front bay adapter provides a versatile solution that lets you install a 3.5" floppy drive, external facing USB hubs, media card readers, and fan controllers into the front bay of your PC computer, with ease. The adapter bracket features an attractive open-faced black bezel that provides a secure fit. The TAA compliant BRACKETFDBK is backed by a StarTech.com 2-year warranty and free lifetime technical support.
StarTech.com 3.5" to 5.25" Front Bay Adapter - Mount 3.5" HDD in 5.25" Bay - Hard Drive Mounting Bracket w/ Mounting Screws (BRACKETFDBK) - storage bay adapter
Storage bay adapter
Expansion Bays
1 x front accessible - 3.5" x 1/3H
Compatible Bay
1 5.25" x 1/2H
Product Material
Metal
14.6 cm x 13.3 cm x 2.9 cm
P/N: 25SATSAS35HD, 35BAYCF2IDE, 35BAYUSB3S4, 35FCREADBK3, 35FCREADBU3, 35SAT225S3R, HSB220SAT25B, HSB225S3R, S251BU31REM, SAT2IDEADP, SATBP125VP, ST521PMINT
Storage bay adapter
Product Material
Metal
Storage Controller
No CPU
Bays
Compatible Bay
1 x external 5.25" x 1/2H
14.6 cm
13.3 cm
2.9 cm
4LV7 StarTech.com 3.5in Hard Drive to 5.25in Front Bay Bracket Adapter In Stock £5.88
4LV7 StarTech.com 3.5in Drive Bay IDE to Single CF SSD Adapter Card Reader In Stock £18.52
4LV7 StarTech.com SATA to 2.5in or 3.5in IDE Hard Drive Adapter for HDD Docks In Stock £19.65
4LV7 StarTech.com 2.5in SATA/SAS SSD/HDD to 3.5in SATA Hard Drive Converter In Stock £13.55
4LV7 StarTech.com 3.5in Front Bay 22-in-1 USB 2.0 Internal Multi Media Memory Card Reader - Black In Stock £11.21
4LV7 StarTech.com 2.5" to 3.5" SATA Aluminium Hard Drive Adapter Enclosure SSD / HDD Height up to 12.5mm In Stock £20.49
4LV7 StarTech.com 2.5 to 3.5 Hard Drive Adapter In Stock £23.17
Type: Bracket
