StarTech.com 4x 2.5" SSD/HDD Mount Bracket
Quicklinx: BVZ7WS00 Mfr#: BRACKET425F
Install four 2.5" solid-state drives or hard drives into two 5.25" front bays, to add storage to a desktop computer or server. Increase the performance and data storage capacity of your desktop computer or enhance your server room storage, with this 4-drive mounting bracket kit for 2.5" solid-state drives or hard drives.
This drive-mounting bracket lets you add four 2.5" SSDs or HDDs into two 5.25" front bays of your computer or server, allowing you to enhance your data storage capacity. The mounting brackets supports a wide range of 2.5" SSDs/HDDs from 5 to 15 mm in height.
A large built-in fan keeps air moving to dissipate heat build-up, and ensure optimum operating temperatures. Protecting against excessive heat build-up maximizes the life of your drives. The fan also features a dust filter making the mounting bracket ideal for industrial or corporate environments.
Engineered with steel framing, the mounting bracket is designed for dependable performance and durability.
StarTech.com 4x 2.5in SSD/HDD Mounting Bracket with Cooling Fan - Four-Drive Mounting Bracket for Desktop Computer or Server (BRACKET425F) - storage bay adapter
Storage bay adapter
Supported Form Factor
5.25" to 2.5"
Expansion Bays
4 x internal - 2.5"
Compatible Bay
2 5.25"
P/N: M2E4SFF8643, PEX4SFF8643
Storage bay adapter
5.25" to 2.5"
Storage Controller
No CPU
Bays
4 x internal - 2.5"
1 - 4 PIN internal power
Compatible Bay
2 x internal 5.25"
Built-in cooling fan
BVZ7 StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter In Stock £5.06
BVZ7 StarTech.com 3.5in Universal Hard Drive Mounting Bracket Adapter for 5.25in Bay In Stock £3.02
BVZ7 StarTech.com 12in LP4 to 2x SATA Power Y Cable Adapter In Stock £4.48
BVZ7 StarTech.com 12in Latching SATA Cable In Stock £6.16
BVZ7 StarTech.com 18in Latching SATA Cable In Stock £4.24
BVZ7 StarTech.com 24in Latching SATA Cable In Stock £6.84
BVZ7 StarTech.com 3.5in Hard Drive to 5.25in Front Bay Bracket Adapter In Stock £5.88
BVZ7 StarTech.com 6in SATA Power Y Splitter Cable Adapter - M/F In Stock £6.34
BVZ7 StarTech.com 6in Latching SATA Cable In Stock £2.60
BVZ7 StarTech.com 2.5in SATA to Mini SATA SSD Adapter Enclosure In Stock £29.96
BVZ7 StarTech.com 4x SATA Power Splitter Adapter Cable In Stock £6.60
BVZ7 StarTech.com Dual 2.5" to 3.5" HDD Bracket for SATA Hard Drives - 2 Drive 2.5" to 3.5" Bracket In Stock £7.24
BVZ7 StarTech.com 2.5" to 3.5" SATA Aluminium Hard Drive Adapter Enclosure SSD / HDD Height up to 12.5mm In Stock £20.49
BVZ7 StarTech.com M.2 NGFF SSD to 2.5in SATA Adapter Converter In Stock £15.57
BVZ7 StarTech.com mSATA SSD to 2.5in SATA Adapter Converter In Stock £18.13
BVZ7 StarTech.com Dual mSATA SSD to 2.5" SATA RAID Adapter Converter In Stock £14.65
BVZ7 StarTech.com Tool-Less 2B Mounting Bracket In Stock £6.49
BVZ7 StarTech.com 6" SATA Power Y Splitter Cable In Stock £6.34
BVZ7 StarTech.com 2.5 to 3.5 Hard Drive Adapter In Stock £23.17
