This 4U 19in Wallmount Bracket offers a versatile storage solution, allowing equipment (Network devices, power strips, patch panels) to be mounted vertically (flush with wall) to save space. Alternatively, the 4U bracket can be installed under a desk for horizontal installation, making it easy to access installed equipment directly from your workspace.
Perfect for SoHo (small office, home office) environments, the wallmount bracket offers space-saving installation for environments lacking the footprint space for a full size server equipment rack.
Suitable for mounting on virtually any wall/ceiling surface (e.g. drywall), the bracket mounting holes (used to mount to a wall or the desk underside) are positioned at exactly 16in apart, matching standard construction framework.
Constructed to EIA-310 19in rack standards, the wallmount bracket features a sturdy steel design.
Need more storage space? StarTech.com also offers a 1U 19in Wallmount Bracket, a 2U 19in Wallmount Bracket and a 3U 19in Wallmount Bracket.
- StarTech.com 4U Wall Mount Patch Panel Bracket - 19 inch Steel Vertical Mounting Bracket for Network and Data Equipment (RK419WALLV) - mounting bracket - 4U
- Product Type
- Mounting bracket
- Placing / Mounting
- Wall mountable
- Black
- Rack Size
- 19"
- Height (Rack Units)
- 4U
- Product Material
- Steel
- 5 cm x 19.4 cm x 15.1 cm
- 1.06 kg
- Limited lifetime warranty
- Product Type
- Mounting bracket
- Wall mountable
- Product Material
- Steel
- Rack Size
- 19"
- 4U
- 5 cm
- 19.4 cm
- 15.1 cm
- 1.06 kg
- Black
- Mounting Kit
- Included
- UL, RoHS
- Limited warranty: - lifetime
StarTech.com 12U 19in Desktop Open Frame 2 Post Rack | In Stock | £45.05 |
StarTech.com 2U 19in Steel Vertical Wall Mount Equipment Rack Bracket | In Stock | £39.16 |
StarTech.com 4U 19in Steel Vertical Wall Mount Equipment Rack Bracket | In Stock | £54.22 |
StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets | In Stock | £13.69 |
StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £35.51 |
StarTech.com 6U 12in Deep Wall Mounting Bracket for Patch Panel | In Stock | £48.81 |
StarTech.com 1U 19in Hinged Wall Mounting Bracket for Patch Panels | In Stock | £16.93 |
StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet | In Stock | £14.45 |
StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £30.08 |
StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £62.10 |
StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £65.60 |
StarTech.com 24 Port 0.5U Cat5e Patch Panel - RJ45 Ethernet Rackmount Cat 5e 110 Patch Panel | In Stock | £35.37 |
StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel | In Stock | £46.00 |
StarTech.com 100 Pkg M6 Screws & Cage Nuts | In Stock | £60.59 |
StarTech.com 50 Pkg M6 Screws & Cage Nuts | In Stock | £32.75 |
StarTech.com 50 Pkg M6 Cage Nuts | In Stock | £22.65 |
StarTech.com 100 Pkg M5 Cage Nuts | In Stock | £28.99 |
StarTech.com 50 Pkg M5 Cage Nuts | In Stock | £17.19 |
StarTech.com 100 Pkg M5 Screws & Cage Nuts | In Stock | £62.10 |
StarTech.com 50 Pkg M5 Screws & Cage Nuts | In Stock | £33.34 |
StarTech.com 50 Pkg M5 Mounting Screws | In Stock | £18.28 |
StarTech.com 100 Pkg M5 Mounting Screws | In Stock | £34.40 |
StarTech.com 50 Pkg M6 Mounting Screws | In Stock | £19.29 |
StarTech.com 100 Pkg M6 Cage Nuts | In Stock | £30.06 |
StarTech.com 19in Cable Management Panel | In Stock | £23.30 |
StarTech.com 4U WM Server Rack with Shelf | In Stock | £103.10 |
StarTech.com 8U WM Server Rack with Shelf | In Stock | £136.71 |
StarTech.com 6U Wall Mount Rack Bracket | In Stock | £73.59 |
StarTech.com 18U Server Rack Enclosure | In Stock | £450.96 |
StarTech.com 6U Wall-Mount Rack Cabinet | In Stock | £148.99 |
StarTech.com 26U Server Rack Enclosure | In Stock | £493.93 |
StarTech.com 9U Wall-Mount Rack Cabinet | In Stock | £174.53 |
StarTech.com 9U Wall-Mount Rack Cabinet | In Stock | £193.99 |
StarTech.com 12U Server Rack Enclosure | In Stock | £343.41 |
StarTech.com 12U Server Rack Enclosure | In Stock | £276.36 |
StarTech.com 15U Server Rack Enclosure | In Stock | £343.34 |
StarTech.com 12U Server Rack Enclosure | In Stock | £375.79 |
StarTech.com M6 Mounting Screws 50Pack | In Stock | £17.85 |
