StarTech.com 9U Wall-Mount Rack Cabinet
Quicklinx: CZDFWS00 Mfr#: RK9WALM
Product Type: Rack enclosure cabinet
13 In Stock
£178.89 ex VAT
£214.66 inc VAT
Use this wall mount network cabinet to mount your equipment to the wall. This 9U server rack cabinet lets you mount your EIA-310 compliant equipment to the wall. The enclosure features an adjustable mounting depth from 6 to 17 in. and offers a maximum load capacity of 200 lb. (90 kg).
Save valuable floor space, by wall-mounting the enclosure. The wall-mounted design makes this enclosure the ideal solution for optimizing equipment storage in your classroom, retail store, server room or office. This rack also includes a 1U shelf that gives you a stable surface for storing your tools or placing equipment that's not rack-mountable.
The wall-mount network rack makes it easy to install your equipment, with 2-post mounting rails that can be positioned to create more room at the front or the back of the enclosure depending on your requirements.
The 9U network cabinet features a removable and reversible front door and removable side panels, each with quick-release mechanisms, so you can easily access your equipment. Plus, each door and panel on this rack features an independent lock, ensuring your equipment is secure. The wall-mount server rack also includes all of the cage nuts and mounting screws you'll need to fill the rack with equipment, saving you the time, hassle and cost of sourcing mounting hardware.
For hassle-free cable management, the rack includes a 3-meter roll of hook-and-loop cable tie that makes it easy to keep your cables neat and tidy by binding them together or binding them to the rack. The self-gripping fabric can be cut to any size, enabling a wrap-around solution for the cables of any rack-mount equipment.
This server rack enclosure features heavy-duty steel construction, with lockable doors at all entrances. For hassle-free equipment installation, the mounting rails on the rack can be switched for use with square holes and cage nuts, or tapped rails.
To ensure your equipment is running at an optimal temperature, the server rack/cabinet promotes passive cooling. It features mesh doors and vented top and bottom panels for maximum airflow.
For simple and sturdy mounting, the rack's mounting holes are positioned 16 in. apart, so you can securely attach it to a wall using wall studs.
  • Save space in your office or server room
  • Easily install your servers and network equipment
    The wall-mount network rack makes it easy to install your equipment, with 2-post mounting rails that can be positioned to create more room at the front or the back of the enclosure depending on your requirements. The 9U network cabinet features a removable and reversible front door and removable side panels, each with quick-release mechanisms, so you can easily access your equipment. Plus, each door and panel on this rack features an independent lock, ensuring your equipment is secure. The wall-mount server rack also includes all of the cage nuts and mounting screws you'll need to fill the rack with equipment, saving you the time, hassle and cost of sourcing mounting hardware. For hassle-free cable management, the rack includes a 3-meter roll of hook-and-loop cable tie that makes it easy to keep your cables neat and tidy by binding them together or binding them to the rack. The self-gripping fabric can be cut to any size, enabling a wrap-around solution for the cables of any rack-mount equipment.
  • Securely protect your equipment
    This server rack enclosure features heavy-duty steel construction, with lockable doors at all entrances. For hassle-free equipment installation, the mounting rails on the rack can be switched for use with square holes and cage nuts, or tapped rails. To ensure your equipment is running at an optimal temperature, the server rack/cabinet promotes passive cooling. It features mesh doors and vented top and bottom panels for maximum airflow. For simple and sturdy mounting, the rack's mounting holes are positioned 16 in. apart, so you can securely attach it to a wall using wall studs.
StarTech.com 2 Post 9U 19" Wall Mount Network Cabinet, Adjustable Depth 6-15" Locking IT Switch Depth Enclosure, Vented Computer/Electronics Equipment Data Rack w/ Shelf + Hook & Loop Tape - 19 Inch Wall Cabinet (RK9WALM) - rack enclosure cabinet - 9U
Placing / Mounting
Wall mountable
Package Content
2 side panel keys, 2 door keys, 36 screws (12-24), roll of hook-and-loop fastener, 36 cage nuts
Height (Rack Units)
9U
Product Material
Steel
60 cm x 45 cm x 50.4 cm
17.5 kg
Lockable front door, key lock, adjustable depth, hinged, mesh front door
5-year warranty
Placing / Mounting
Wall mountable
Product Material
Steel
Package Content
Height (Rack Units)
9U
60 cm
45 cm
50.4 cm
17.5 kg
Inner Dimensions
45 cm x 43 cm x 40 cm
Weight Limit
90 kg
Limited warranty: - 5 years
CZDF StarTech.com 8U Open Frame Wall Mount Equipment Rack - 12in Deep In Stock £68.51
CZDF StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £12.20
CZDF StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £30.66
CZDF StarTech.com Black Standard Universal Server Rack Cabinet Shelf In Stock £30.71
CZDF StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet In Stock £14.39
CZDF StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £28.24
CZDF StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £54.39
CZDF StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £57.53
CZDF StarTech.com 24 Port 0.5U Cat5e Patch Panel - RJ45 Ethernet Rackmount Cat 5e 110 Patch Panel In Stock £15.50
CZDF StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 2.2x3.9in (5.7x10cm) In Stock £3.06
CZDF StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 1.8x3.9in (4.5x10cm) In Stock £4.24
CZDF StarTech.com Multi-Directional Vertical Server Rack Cable Management D-Ring Hook 2.4x3.9in (6x10cm) In Stock £6.36
CZDF StarTech.com 1U Brush Strip Horizontal Server Rack Cable Management Panel In Stock £38.59
CZDF StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel In Stock £47.16
CZDF StarTech.com 1U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £17.75
CZDF StarTech.com 2U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £23.11
CZDF StarTech.com 100 Pkg M6 Screws & Cage Nuts In Stock £56.58
CZDF StarTech.com 50 Pkg M6 Screws & Cage Nuts In Stock £30.63
CZDF StarTech.com 50 Pkg M6 Cage Nuts In Stock £20.19
CZDF StarTech.com 100 Pkg M5 Cage Nuts In Stock £9.55
CZDF StarTech.com 50 Pkg M5 Cage Nuts In Stock £5.39
CZDF StarTech.com 100 Pkg M5 Screws & Cage Nuts In Stock £53.55
CZDF StarTech.com 50 Pkg M5 Screws & Cage Nuts In Stock £28.25
CZDF StarTech.com 100 Pkg M5 Mounting Screws In Stock £29.69
CZDF StarTech.com 50 Pkg M6 Mounting Screws In Stock £16.56
CZDF StarTech.com 100 Pkg M6 Cage Nuts In Stock £26.89
CZDF StarTech.com 100 Pkg M6 Cage Nuts In Stock £27.11
CZDF Startech.com 100 Pkg M6 Mounting Screws In Stock £26.84
CZDF StarTech.com 19in Cable Management Panel In Stock £24.18
CZDF StarTech.com Heavy Duty Casters for Server Racks/Cabinets - Set of 4 In Stock £36.61
CZDF StarTech.com M6 Mounting Screws 50Pack In Stock £16.56
CZDF StarTech.com 42U Server Rack Cabinet In Stock £1,258.59
