StarTech.com 4U 19in Steel Vertical Wall Mount Equipment Rack Bracket
Quicklinx: 6B9WWS00 Mfr#: RK419WALLV
Product Type: Mounting bracket
Hurry, only 2 left in stock!
£54.22 ex VAT
£65.06 inc VAT
This 4U 19in Wallmount Bracket offers a versatile storage solution, allowing equipment (Network devices, power strips, patch panels) to be mounted vertically (flush with wall) to save space. Alternatively, the 4U bracket can be installed under a desk for horizontal installation, making it easy to access installed equipment directly from your workspace.
Perfect for SoHo (small office, home office) environments, the wallmount bracket offers space-saving installation for environments lacking the footprint space for a full size server equipment rack.
Suitable for mounting on virtually any wall/ceiling surface (e.g. drywall), the bracket mounting holes (used to mount to a wall or the desk underside) are positioned at exactly 16in apart, matching standard construction framework.
Constructed to EIA-310 19in rack standards, the wallmount bracket features a sturdy steel design.
Need more storage space? StarTech.com also offers a 1U 19in Wallmount Bracket, a 2U 19in Wallmount Bracket and a 3U 19in Wallmount Bracket.
StarTech.com 4U Wall Mount Patch Panel Bracket - 19 inch Steel Vertical Mounting Bracket for Network and Data Equipment (RK419WALLV) - mounting bracket - 4U
Mounting bracket
Placing / Mounting
Wall mountable
Rack Size
19"
Height (Rack Units)
4U
Product Material
Steel
5 cm x 19.4 cm x 15.1 cm
1.06 kg
Mounting bracket
Placing / Mounting
Wall mountable
Product Material
Steel
Rack Size
19"
Height (Rack Units)
4U
5 cm
19.4 cm
15.1 cm
1.06 kg
Mounting Kit
Included
UL, RoHS
Limited warranty: - lifetime
6B9W StarTech.com 12U 19in Desktop Open Frame 2 Post Rack In Stock £42.34
6B9W StarTech.com 2U 19in Steel Vertical Wall Mount Equipment Rack Bracket In Stock £35.98
6B9W StarTech.com 4U 19in Steel Vertical Wall Mount Equipment Rack Bracket In Stock £54.22
6B9W StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £12.34
6B9W StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £31.00
6B9W StarTech.com 6U 12in Deep Wall Mounting Bracket for Patch Panel In Stock £48.81
6B9W StarTech.com 1U 19in Hinged Wall Mounting Bracket for Patch Panels In Stock £16.93
6B9W StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet In Stock £14.45
6B9W StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £29.01
6B9W StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £54.09
6B9W StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £57.23
6B9W StarTech.com 8U Open Frame Wall Mount Equipment Rack - Adjustable Depth In Stock £131.41
6B9W StarTech.com 24 Port 0.5U Cat5e Patch Panel - RJ45 Ethernet Rackmount Cat 5e 110 Patch Panel In Stock £33.04
6B9W StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel In Stock £46.00
6B9W StarTech.com 100 Pkg M6 Screws & Cage Nuts In Stock £57.09
6B9W StarTech.com 50 Pkg M6 Screws & Cage Nuts In Stock £30.93
6B9W StarTech.com 100 Pkg M5 Cage Nuts In Stock £26.80
6B9W StarTech.com 50 Pkg M6 Cage Nuts In Stock £20.46
6B9W StarTech.com 100 Pkg M5 Cage Nuts In Stock £28.99
6B9W StarTech.com 50 Pkg M5 Cage Nuts In Stock £15.59
6B9W StarTech.com 100 Pkg M5 Screws & Cage Nuts In Stock £54.01
6B9W StarTech.com 50 Pkg M5 Screws & Cage Nuts In Stock £29.06
6B9W StarTech.com 50 Pkg M5 Mounting Screws In Stock £16.04
6B9W StarTech.com 100 Pkg M5 Mounting Screws In Stock £29.99
6B9W StarTech.com 50 Pkg M6 Mounting Screws In Stock £16.75
6B9W StarTech.com 100 Pkg M6 Cage Nuts In Stock £27.29
6B9W StarTech.com 100 Pkg M6 Cage Nuts In Stock £28.49
6B9W StarTech.com 19in Cable Management Panel In Stock £23.30
6B9W StarTech.com 4U WM Server Rack with Shelf In Stock £103.10
6B9W StarTech.com 8U WM Server Rack with Shelf In Stock £136.71
6B9W StarTech.com 6U Wall Mount Rack Bracket In Stock £68.29
6B9W StarTech.com 18U Server Rack Enclosure In Stock £383.80
6B9W StarTech.com 6U Wall-Mount Rack Cabinet In Stock £148.99
6B9W StarTech.com 26U Server Rack Enclosure In Stock £481.62
6B9W StarTech.com 9U Wall-Mount Rack Cabinet In Stock £174.53
6B9W StarTech.com 9U Wall-Mount Rack Cabinet In Stock £193.99
6B9W StarTech.com 12U Server Rack Enclosure In Stock £343.41
6B9W StarTech.com 12U Server Rack Enclosure In Stock £276.36
6B9W StarTech.com 15U Server Rack Enclosure In Stock £324.97
6B9W StarTech.com 12U Server Rack Enclosure In Stock £375.79
6B9W StarTech.com M6 Mounting Screws 50Pack In Stock £16.78
