StarTech.com 4U 19in Steel Vertical Wall Mount Equipment Rack Bracket
Quicklinx: 6B9WWS00 Mfr#: RK419WALLV
Product Type: Mounting bracket
£51.13 ex VAT
£61.35 inc VAT
This 4U 19in Wallmount Bracket offers a versatile storage solution, allowing equipment (Network devices, power strips, patch panels) to be mounted vertically (flush with wall) to save space. Alternatively, the 4U bracket can be installed under a desk for horizontal installation, making it easy to access installed equipment directly from your workspace.
Perfect for SoHo (small office, home office) environments, the wallmount bracket offers space-saving installation for environments lacking the footprint space for a full size server equipment rack.
Suitable for mounting on virtually any wall/ceiling surface (e.g. drywall), the bracket mounting holes (used to mount to a wall or the desk underside) are positioned at exactly 16in apart, matching standard construction framework.
Constructed to EIA-310 19in rack standards, the wallmount bracket features a sturdy steel design.
Need more storage space? StarTech.com also offers a 1U 19in Wallmount Bracket, a 2U 19in Wallmount Bracket and a 3U 19in Wallmount Bracket.
  • Sturdy construction
    Crafted from robust steel, this mounting bracket ensures stability and durability for all network and data equipment installations.
  • Space-saving solution
    Designed for vertical mounting, this bracket helps organize and optimize workspace, keeping network equipment neat and accessible.
  • Easy installation
    Comes with a complete mounting kit, allowing for quick and straightforward setup without the need for additional hardware.
  • Compliant standards
    This product adheres to UL and RoHS regulations, providing peace of mind regarding safety and environmental impact.
  • Standardized size
    Designed to accommodate 19-inch racks, making it versatile and compatible with a wide range of networking equipment.
StarTech.com 4U Wall Mount Patch Panel Bracket - 19 inch Steel Vertical Mounting Bracket for Network and Data Equipment (RK419WALLV) - mounting bracket - 4U
Mounting bracket
Placing / Mounting
Wall mountable
Rack Size
19"
Height (Rack Units)
4U
Product Material
Steel
5 cm x 19.4 cm x 15.1 cm
1.06 kg
Mounting bracket
Placing / Mounting
Wall mountable
Product Material
Steel
Rack Size
19"
Height (Rack Units)
4U
5 cm
19.4 cm
15.1 cm
1.06 kg
Mounting Kit
Included
UL, RoHS
Limited warranty: - lifetime
6B9W StarTech.com 12U 19in Desktop Open Frame 2 Post Rack In Stock £40.61
6B9W StarTech.com 2U 19in Steel Vertical Wall Mount Equipment Rack Bracket In Stock £34.65
6B9W StarTech.com 4U 19in Steel Vertical Wall Mount Equipment Rack Bracket In Stock £51.13
6B9W StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £11.90
6B9W StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £29.91
6B9W StarTech.com 6U 12in Deep Wall Mounting Bracket for Patch Panel In Stock £48.26
6B9W StarTech.com 1U 19in Hinged Wall Mounting Bracket for Patch Panels In Stock £16.23
6B9W StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet In Stock £14.39
6B9W StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £27.99
6B9W StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £52.23
6B9W StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £55.25
6B9W StarTech.com 8U Open Frame Wall Mount Equipment Rack - Adjustable Depth In Stock £129.80
6B9W StarTech.com 24 Port 0.5U Cat5e Patch Panel - RJ45 Ethernet Rackmount Cat 5e 110 Patch Panel In Stock £31.67
6B9W StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel In Stock £46.00
6B9W StarTech.com 100 Pkg M6 Screws & Cage Nuts In Stock £55.20
6B9W StarTech.com 50 Pkg M6 Screws & Cage Nuts In Stock £29.89
6B9W StarTech.com 100 Pkg M5 Cage Nuts In Stock £25.96
6B9W StarTech.com 50 Pkg M6 Cage Nuts In Stock £19.69
6B9W StarTech.com 100 Pkg M5 Cage Nuts In Stock £29.98
6B9W StarTech.com 50 Pkg M5 Cage Nuts In Stock £15.03
6B9W StarTech.com 100 Pkg M5 Screws & Cage Nuts In Stock £52.24
6B9W StarTech.com 50 Pkg M5 Mounting Screws In Stock £15.48
6B9W StarTech.com 100 Pkg M5 Mounting Screws In Stock £28.96
6B9W StarTech.com 50 Pkg M6 Mounting Screws In Stock £16.16
6B9W StarTech.com 100 Pkg M6 Cage Nuts In Stock £26.90
6B9W StarTech.com 100 Pkg M6 Cage Nuts In Stock £27.56
6B9W StarTech.com 19in Cable Management Panel In Stock £23.58
6B9W StarTech.com 4U WM Server Rack with Shelf In Stock £103.10
6B9W StarTech.com 8U WM Server Rack with Shelf In Stock £136.71
6B9W StarTech.com 6U Wall Mount Rack Bracket In Stock £64.77
6B9W StarTech.com 18U Server Rack Enclosure In Stock £369.77
6B9W StarTech.com 6U Wall-Mount Rack Cabinet In Stock £148.99
6B9W StarTech.com 26U Server Rack Enclosure In Stock £463.46
6B9W StarTech.com 9U Wall-Mount Rack Cabinet In Stock £174.53
6B9W StarTech.com 9U Wall-Mount Rack Cabinet In Stock £193.99
6B9W StarTech.com 12U Server Rack Enclosure In Stock £330.35
6B9W StarTech.com 12U Server Rack Enclosure In Stock £280.72
6B9W StarTech.com 15U Server Rack Enclosure In Stock £313.10
6B9W StarTech.com 12U Server Rack Enclosure In Stock £375.79
6B9W StarTech.com M6 Mounting Screws 50Pack In Stock £16.79
