StarTech.com 4Slot USBC Card Reader USB 3.1
Quicklinx: DWZQWS00 Mfr#: 4SD4FCRU31C
Access any four SD cards simultaneously on your USB-C enabled device, with this ultra-fast card reader. This USB-C SD card reader lets you access four SD cards simultaneously.
You can: Download and edit photos and videos; Back up documents and critical data from multiple users; Deploy system updates in batches; Distribute content to multiple employees.
The card reader transfers files between your USB-C, Thunderbolt 3 or USB-A laptop or desktop computer and the reader.
The reader features SD 4.0 and UHS-II support. It reads and writes to and from the cards at speeds of up to 312MB/s. The reader also supports USB 3.1 connection speeds of up to 10Gbps to ensure maximum transfer rates between the computer and the reader, while simultaneously accessing all four cards.
The card reader is also backward compatible with earlier versions of USB (3.0, 2.0 and 1.1).
The card reader supports all SD cards: SD (Secure Digital), SDHC (Secure Digital High Capacity) and SDXC (Secure Digital Extended Capacity). It also supports UHS cards, and is backward compatible with older SD card versions.
The card reader will also support the following card types when connected through an adapter: microSD; miniSD; MMCmobile; RS-MMC; MMCplus.
The small footprint design fits in nicely with your workstation. Place the card reader on your desk without taking up too much space.
StarTech.com 4-Slot SD Card Reader - USB 3.1 (10Gbps) SD Card Reader - USB-C SD Card Reader w/ support for SD 4.0, UHS-II (4SD4FCRU31C) - card reader - USB 3.1
Card reader - external
Supported Memory Cards
MultiMediaCard, SD Memory Card, SDHC UHS-II Memory Card, SDXC UHS-II Memory Card
Host Interface
USB 3.1
P/N: STNDTBLT1A5T
Host Interface
USB 3.1
7 cm
17.7 cm
1.7 cm
335 g
Memory Card
(max)
Required Ports
1 x 24 pin USB-C
AC 120/230 V
2 USB cables, power adapter
Shipping Weight
335 g
P/N: STNDTBLT1A5T
DWZQ StarTech.com 3.5in Drive Bay IDE to Single CF SSD Adapter Card Reader In Stock £18.52
DWZQ StarTech.com 3.5in Front Bay 22-in-1 USB 2.0 Internal Multi Media Memory Card Reader - Black In Stock £11.21
DWZQ StarTech.com 1m USB 3.1 USB-C to USB-A Cbl In Stock £7.59
DWZQ StarTech.com 1m 3ft USB 3.1 USB-C Cable M/M In Stock £13.21
DWZQ StarTech.com 0.5m USB C Cable - USB 3.1 In Stock £12.76
DWZQ StarTech.com 0.5m USB to USB-C Cable 10Gbps In Stock £9.86
DWZQ StarTech.com USB Multi-Media Card Reader In Stock £17.10
