StarTech.com 3.5in Front Bay 22-in-1 USB 2.0 Internal Multi Media Memory Card Reader - Black
Quicklinx: 8VVCWS00 Mfr#: 35FCREADBK3
34 In Stock
£11.21 ex VAT
£13.45 inc VAT
Add front panel access to 22 different types of flash memory cards. The 35FCREADBK3 3.5" Multimedia Card Reader offers quick and easy access to the most popular flash card formats, from the front panel of almost any desktop computer.
Suitable for quickly accessing memory cards from virtually any portable media device (e.g. digital cameras, MP3 players, etc.), this versatile media card reader supports 22 of the most popular card types, including: Compact Flash (CF type I/II), Secure Digital (SD/miniSD/microSD/SDHC/SDXC), MultiMediaCard (MMC/RS-MMC/HS-MMC/MMCmobile/MMCplus/MMCmicro/HC-MMC), MemoryStick (MS/MS Duo/HS-MS/MS PRO/MS PRO Duo/MS PRO-HG Duo/MS-ROM/M2), and xD Picture cards, this reader is ready to handle the memory cards from virtually any portable device from cameras to music players.
The card reader also allows simultaneous access to multimedia card types (excluding same type media), allowing you to copy files from or between different cards at the same time.
  • Versatile compatibility
    This card reader supports a wide array of flash memory formats, enabling access to CompactFlash, SD memory cards, Memory Stick types, and more, catering to diverse user needs.
  • Efficient data transfer
    Equipped with a USB 2.0 interface, this reader provides reliable speeds for transferring files, ensuring that users can manage their media quickly.
  • Easy installation
    The included USB cable and mounting kit streamline the setup, allowing for quick integration into any computer system.
  • User-friendly design
    The front-accessible feature allows users to easily insert and remove memory cards without needing to navigate behind the computer.
  • Compact form factor
    Designed to fit neatly into a standard 3.5-inch internal bay, the card reader maximizes space while providing functionality.
StarTech.com 3.5in Front Bay 22-in-1 USB 2.0 Internal Multi Media Memory Card Reader with Simultaneous Access - CF/SD/MMC/MS/xD - Black (35FCREADBK3) - card reader - USB 2.0
Card reader - internal - 22 in 1
Supported Memory Cards
CompactFlash Card type I, CompactFlash Card type II, Memory Stick, Memory Stick PRO, MultiMediaCard, SD Memory Card, Memory Stick Duo, xD-Picture Card, Memory Stick PRO Duo, miniSD, RS-MMC, MultiMediaCardmobile, microSD, MultiMediaCardplus, MultiMediaCardmicro, SDHC Memory Card, Memory Stick Micro (M2), microSDHC, Memory Stick PRO-HG Duo, SDXC Memory Card, microSDXC
Host Interface
USB 2.0
Required Bay
3.5" internal
Status indicator
Host Interface
USB 2.0
Required Bay
3.5" internal
Status indicator
10.5 cm
13 cm
2.5 cm
164 g
Memory Card
(max)
Additional Ports
1 x USB 2.0
Required Ports
1 x 9 pin USB header
Microsoft Windows 2000, Linux Kernel 2.4 or later, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits)
USB cable, mounting kit
FCC, RoHS
8VVC StarTech.com 3.5in Hard Drive to 5.25in Front Bay Bracket Adapter In Stock £5.88
8VVC StarTech.com 10ft USB 2.0 Extension Cable A to A - M/F In Stock £5.00
8VVC StarTech.com 3 ft Black USB 2.0 Extension Cable A to A - M/F In Stock £4.06
8VVC StarTech.com 6 ft Black USB 2.0 Extension Cable A to A - M/F In Stock £4.19
8VVC StarTech.com 6in USB 2.0 Extension Adapter Cable A to A - M/F In Stock £4.74
Supported Formats: CompactFlash Card type I
Supported Formats: Memory Stick Micro (M2)
Supported Formats: MultiMediaCard
Supported Formats: RS-MMC
Supported Formats: SD Memory Card
Supported Formats: CompactFlash Card type II
Supported Formats: Memory Stick PRO
Supported Formats: MultiMediaCardmobile
Supported Formats: MultiMediaCardplus
Supported Formats: microSDHC
Supported Formats: xD-Picture Card
Supported Formats: miniSD
Supported Formats: Memory Stick Duo
Supported Formats: Memory Stick PRO Duo
Supported Formats: Memory Stick PRO-HG Duo
Supported Formats: MultiMediaCardmicro
Supported Formats: SDHC Memory Card
Supported Formats: SDXC Memory Card
Supported Formats: microSDXC
Interface: USB 2.0
