StarTech.com 4m USB 2.0 C Cable w/ PD (5A)
Quicklinx: CTWDWS00 Mfr#: USB2C5C4M
Length: 4m
£17.50 ex VAT
£21.00 inc VAT
Power your USB Type-C devices over longer distances. This USB-C cable with USB Power Delivery lets you power USB Type-C devices from your USB-C laptop or charge your USB-C laptop from a USB-C wall charger.
With up to 5A (100W) of power output, you can use this USB Type-C cable to power and charge a USB-C laptop, such as your Apple MacBook or Chromebook Pixel, using a USB-C wall charger, car charger or power bank. Or, you can power your laptop from a USB-C docking station.
The 5A of power delivery lets you charge your mobile devices faster than with a regular USB-C 2.0 cable. The cable is perfect for people on the move - decrease your charge times and make sure your mobile devices are ready, whenever you need them, while you're on the road.
The non-standard 4-meter cable gives you the extra length you need to overcome distance restrictions and stay connected. You can charge and sync your USB-C mobile device, in almost any environment. Even while you're taking notes in a boardroom, catching up on emails in your hotel room, or reading in a coffee shop, the connection to your mobile device will reach your computer or wall charger more comfortably.
The cable has undergone rigorous compliance testing and is certified by USB-IF (USB Implementers Forum) to meet all USB 2.0 specifications. This includes all environmental, electrical and mechanical standards, which ensures a reliable and high-quality cable for all of your USB-C devices.
StarTech.com 4m USB C Cable w/ PD - 13ft USB Type C Cable - 5A Power Delivery - USB 2.0 USB-IF Certified - USB 2.0 Type-C Cable - 100W/5A (USB2C5C4M) - USB-C cable - 24 pin USB-C to 24 pin USB-C - 4 m
USB-C cable
Sync and charge
Length
4 m
Connector
24 pin USB-C - male
Connector (Second End)
24 pin USB-C - male
Rated Current
5 A
USB / USB 2.0
P/N: CDP2HVGUASPD, CDP2VGAUACP, CDP2VGAUCP, DKT30CHCPD, DKT30CHD, DKT30CHPD, DKT30CHPD3, DKT30CHPDW, DKT30CHVSDPD, DKT31CMDPHPD
USB-C cable
Rated Current
5 A
Sync and charge
Length
4 m
Connector
24 pin USB-C - male
24 pin USB-C - male
USB / USB 2.0, USB-IF
CTWD StarTech.com USB-C Cable - M/M - 1m (3ft.) - USB 2.0 In Stock £9.47
CTWD StarTech.com 2m 6ft USB 2.0 USB-C Cable In Stock £11.21
CTWD StarTech.com 4m USB 2.0 C Cable w/ PD (5A) In Stock £17.50
CTWD StarTech.com 3m 10ft USB C Cable w/ 5A PD In Stock £19.10
CTWD StarTech.com 1m 3ft USB C Cable w/ 5A PD In Stock £11.39
CTWD StarTech.com USB 2.0 - C to C w/ 5A PD - 6 ft / 2m In Stock £15.89
CTWD StarTech.com 2m USB 2.0 Certified Power Delivery(5A) C to C White Cable In Stock £13.94
CTWD StarTech.com 4m USB 2.0 Power Delivery(5A) C to C White Cable - M/M In Stock £15.47
CTWD StarTech.com 50cm USB 2.0 Power Delivery(5A) C to C Cable - M/M In Stock £10.19
Length: 4m
