StarTech.com USB-C Cable - M/M - 1m (3ft.) - USB 2.0
Quicklinx: BWGJWS00 Mfr#: USB2CC1M
Length: 1m
26 In Stock
£9.01 ex VAT
£10.81 inc VAT
Charge your USB 2.0 USB-C devices, such as your MacBook or Chromebook, from a USB-C AC wall charger. This USB-C to USB-C cable lets you charge and sync your USB Type-C devices. It's also compatible with Thunderbolt 3 ports.
Connect your newer USB-C mobile devices, such as the Nokia N1 tablet and Nexus 6P and 5X phones, to your computer. The cable delivers up to a 3 amp charge, and supports data transfer speeds of up to 480Mbps.
With up to 3A of power output, this USB Type-C cable can also be used to power a USB-C laptop, such as your Apple MacBook or Chromebook Pixel . Simply connect your laptop to your USB-C wall charger.
Replace the cable that came with your device, or keep one as a spare while you're traveling, so that all of your devices will be ready to use whenever you need them while you're on the road.
The USB Type-C connector is smaller and easier to use than previous USB connectors. With a reversible design, you can plug it into your devices with either side facing up. Insert the cable the right way every time - no more frustration or port damage.
This USB-C cable has been certified with USB-IF (USB Implementers Forum) in order to meet all USB 2.0 specifications. This includes all environmental, electrical and mechanical standards set by USB compliance. This ensures a high-quality, reliable cable for all your USB-C devices.
StarTech.com 1m / 3.3ft USB C to USB C Cable - USB 2.0 Type C Cable - M/M - USB-IF Certified - USB C Charging Cable - USB 2.0 (USB2CC1M) - USB-C cable - 24 pin USB-C to 24 pin USB-C - 1 m
USB-C cable
Double shielded
480 Mbps data rate
Length
1 m
Connector
24 pin USB-C - male
Connector (Second End)
24 pin USB-C - male
USB / USB 2.0
P/N: DKT30CHD, HB30C1A1CPD, HB30C3A1CFBW, PEXUS313AC2V
USB-C cable
Double shielded
Jacket Material
PVC
American Wire Gauge (AWG)
22/30
Plated Connector
Nickel
480 Mbps data rate
Length
1 m
25 g
Connector
24 pin USB-C - male
24 pin USB-C - male
USB / USB 2.0, RoHS
BWGJ StarTech.com 1m USB 2.0 C to Micro-USB Cable In Stock £7.73
BWGJ StarTech.com USB 3.1 USB-C to USB-A Adapter In Stock £9.01
BWGJ StarTech.com 1m USB 3.1 USB-C to USB-A Cbl In Stock £7.59
BWGJ StarTech.com 1m USB 3.1 C to Micro-B Cable In Stock £10.24
BWGJ StarTech.com 1m 3ft USB 3.1 USB-C Cable M/M In Stock £13.21
BWGJ StarTech.com 1m USB 2.0 USB-C to USB-B Cable In Stock £9.97
BWGJ StarTech.com USB-C Cable - M/M - 1m (3ft.) - USB 2.0 In Stock £9.01
BWGJ StarTech.com USB 3.0 USB-C to USB-A Adapter In Stock £8.24
BWGJ StarTech.com USB-C to Micro-USB Adapter M/F In Stock £4.59
BWGJ StarTech.com 6ft USB-C to A Cable - USB 2.0 In Stock £11.87
BWGJ StarTech.com 2m 6ft USB 2.0 USB-C Cable In Stock £11.19
BWGJ StarTech.com 4m USB 2.0 C Cable w/ PD (5A) In Stock £15.43
BWGJ StarTech.com 0.5m USB 2.0 USB C Cable In Stock £8.74
BWGJ StarTech.com 1m Lightning USB C Micro-B Cbl In Stock £24.61
BWGJ StarTech.com 1m Right Angle USB C Cable In Stock £10.49
BWGJ StarTech.com 3m USB 2.0 Type C Cable In Stock £11.57
BWGJ StarTech.com 1m 3ft USB 3.1 C to B Cable In Stock £14.97
Length: 1m
