Power your USB Type-C devices over longer distances. This USB-C cable with USB Power Delivery lets you power USB Type-C devices from your USB-C laptop or charge your USB-C laptop from a USB-C wall charger.
With up to 5A (100W) of power output, you can use this USB Type-C cable to power and charge a USB-C laptop, such as your Apple MacBook or Chromebook Pixel, using a USB-C wall charger, car charger or power bank. Or, you can power your laptop from a USB-C docking station.
The 5A of power delivery lets you charge your mobile devices faster than with a regular USB-C 2.0 cable. The cable is perfect for people on the move - decrease your charge times and make sure your mobile devices are ready, whenever you need them, while you're on the road.
The non-standard 4-meter cable gives you the extra length you need to overcome distance restrictions and stay connected. You can charge and sync your USB-C mobile device, in almost any environment. Even while you're taking notes in a boardroom, catching up on emails in your hotel room, or reading in a coffee shop, the connection to your mobile device will reach your computer or wall charger more comfortably.
The cable has undergone rigorous compliance testing and is certified by USB-IF (USB Implementers Forum) to meet all USB 2.0 specifications. This includes all environmental, electrical and mechanical standards, which ensures a reliable and high-quality cable for all of your USB-C devices.
                Durable designThe cable features a robust construction that can withstand daily wear and tear, ensuring long-lasting use.
                High power deliveryWith its 5 A rating, this cable allows for quick charging of devices, making it a perfect companion for fast-paced lifestyles.
                Flexible connectivityThe 4 m length provides ample reach for connecting devices at a distance, offering convenience in various setups.
                Certified compatibilityCompliant with USB-IF standards, this cable ensures reliable performance with various USB-C devices.
- StarTech.com 4m USB C Cable w/ PD - 13ft USB Type C Cable - 5A Power Delivery - USB 2.0 USB-IF Certified - USB 2.0 Type-C Cable - 100W/5A (USB2C5C4M) - USB-C cable - 24 pin USB-C to 24 pin USB-C - 4 m
- USB-C cable
- Sync and charge
- Length
- 4 m
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- Rated Current
- 5 A
- USB / USB 2.0
- 2-year warranty
- Designed For
- P/N: CDP2HVGUASPD, CDP2VGAUACP, CDP2VGAUCP, DKT30CHCPD, DKT30CHD, DKT30CHPD, DKT30CHPD3, DKT30CHPDW, DKT30CHVSDPD, DKT31CMDPHPD
- USB-C cable
- Rated Current
- 5 A
- Sync and charge
- Length
- 4 m
- Connector
- USB / USB 2.0, USB-IF
- 2-year warranty
- Designed For
|  | StarTech.com USB-C Cable - M/M - 1m (3ft.) - USB 2.0 | In Stock | £9.00 |
|  | StarTech.com 2m 6ft USB 2.0 USB-C Cable | In Stock | £11.23 |
|  | StarTech.com 4m USB 2.0 C Cable w/ PD (5A) | In Stock | £15.41 |
|  | StarTech.com 3m 10ft USB C Cable w/ 5A PD | In Stock | £18.66 |
|  | StarTech.com 1m 3ft USB C Cable w/ 5A PD | In Stock | £10.17 |
|  | StarTech.com USB 2.0 - C to C w/ 5A PD - 6 ft / 2m | In Stock | £14.47 |
|  | StarTech.com 2m USB 2.0 Certified Power Delivery(5A) C to C White Cable | In Stock | £13.23 |
|  | StarTech.com 4m USB 2.0 Power Delivery(5A) C to C White Cable - M/M | In Stock | £13.94 |
|  | StarTech.com 50cm USB 2.0 Power Delivery(5A) C to C Cable - M/M | In Stock | £9.67 |
