Connect fiber network devices for high-speed transfers with LSZH rated cable. The SMFIBLCSC4 4m LC to SC Single-Mode Duplex Fiber Cable features 9/125 micron fiber for high-speed, high bandwidth data transmissions over Gigabit Ethernet and Fiber Channel networks, with support for duplex single-mode applications.
This LC-SC patch cable is housed in a LSZH (Low-Smoke, Zero-Halogen) flame retardant jacket, to ensure minimal smoke, toxicity and corrosion when exposed to high sources of heat, in the event of a fire - an ideal solution for use in industrial settings, central offices and schools, as well as residential settings where building codes are a consideration.
Each Duplex 9/125 (OS1) Single-Mode Fiber Patch Cable is individually tested and certified to be within acceptable optical insertion loss limits for guaranteed compatibility and 100% reliability.
- StarTech.com 4m Fiber Optic Cable - Single-Mode Duplex 9/125 - LSZH - LC/SC - OS1 - LC to SC Fiber Patch Cable (SMFIBLCSC4) - patch cable - 4 m - yellow
- Patch cable - OS1
- Technology
- Duplex fibre optic
- Molded
- Length
- 4 m
- Core / Cladding Diameter
- 9 / 125 micron
- Connector
- 2 x SC single-mode - male
- Connector (Second End)
- 2 x LC single-mode - male
- Yellow
- Limited lifetime warranty
- Network Cable Type
- Patch cable - OS1
- Technology
- Jacket Material
- Low Smoke Zero Halogen (LSZH)
- 9 / 125 micron
- Molded
- Length
- 4 m
- Yellow
- Connector
- RoHS
StarTech.com 1m Single Mode Duplex Fiber Patch Cable LC-SC | In Stock | £16.65 |
StarTech.com 10m Single Mode Duplex Fiber Patch Cable LC-SC | In Stock | £24.73 |
